d series hasport mounts
I'm considering getting a set of d series hasport mounts for my 1990 CRX with ZC swap, anyone have any pictures of this mount set? In particular I'm interested in the driver side mount because the bracket on the motor has two holes but in pictures I'm only seeing one hole on the hasport mount
Theres one hole on top which uses the stud and nut. On bottom it uses a bolt and washer which is provided. I have this kit and its nice and plenty firm. Sorry I don have any pictures though.
Pretty sure he was reffering to SOHC vs DOHC in this. But! The HASport mounts are top notch. Just give them a call, tell them your car and motor and they will give you the item number and it will work.
The engine side mount would be different if he had a ZC vtec. Then I think think he would want the special mount from HASport that compensate for the engine tilt and doesn't require the upper belt housing to be cut into.
Our ESP EF D series kit has a 1 piece transmission mount, a lot easier and stronger then the 2 piece using stock bottom bracket
One hole is a stud, one is a bolt on the driver side.
I also just started making the EF Cable D Rear Bracket... some people are snaping the OEM units with not that much added power...
strawberry
Mar 14, 2008 04:34 PM
AnitRiceSuperStar
Feb 21, 2004 11:39 PM
ForceFed Coupe
Dec 13, 2003 04:19 PM
