My crx wont crank !
hey people , need some help figuring out my problem , my crx wont crank over. my dash lights dont come on and when i hook it up to a jumper the lights come on and it still doesnt crank over ? anybody care to share some thoughts ?
Hit your starter with a hammer a couple times. See if it starts. If it does, probably time for a new starter. If not, check wires.
Yeah, but starters do die. That's why I said hit it with a hammer. I drove my car for a couple weeks with the hammer trick while I waited on my paycheck.
check ALL fuses, make sure it has gas, and listen to hear if you got the fuel pump priming when in the on position. If not then sounds like we're in the same boat. any codes?
lol its none of the fuses , its not my fuel pump or main relay , i can hear it prime when i turn it to on position
This is definitely a ground issue. I would put it in neutral, turn the key to on, run some cable from the battery straight to the starter and see if it cranks.
spdytalk
Honda CR-V & Element
Apr 16, 2013 04:33 AM
superhatchbackbros
50
Jun 1, 2009 11:17 PM
