Replaced the clutch this weekend.
Replaced the clutch on my 93 EX this weekend. The old one was burnt out. Went smoothly, just our first time performing surgery on an import. My question now is; I only have about an inch of clutch pedal, really close to the floor. Should I re-bleed it? or are there other things that could be causing this? Sorry, new to the Honda game.
Did you disconnect/open the hydraulic line, or just unbolt the clutch slave cylinder, leaving the line connected?
You can adjust the pedal a bit where the U-bracket connects to the clutch master cylinder pushrod, like so:
How much pedal travel did you have previously?
