Where can I buy rear Balancer shaft gasket
I am about to put timing belt on and just going to inch my way to find TDC sinc by turning crank an inch...then the cam an inch at a time counter clockwise. Also, I need to replace the a gasket that goes behind my rear balance shaft pulley on my 1997 Honda odyssey lx 2.2 lt motor. The gasket (not the oil seal) is like the water pump black rubber un ordinary shape gasket that fits into the groves. It is number 5 part in the motor-tear apart diagram. https://www.google.com/search?q=1997...103%3B554Thank you, Michael
Vin: JHMRA1864VC016225
