2002 Honda Accord Water Problem.
Old Oct 26, 2013 | 08:42 AM
NicoAnn94's Avatar
Default 2002 Honda Accord Water Problem.
My 2002 Honda Accord Special Edition seems to keep getting water on the floors and my seats are sometimes damp. Everything else is dry and the car is not moved when it rains and I put a tarp over it. I don't know where the water is coming from can someone help?
Old Oct 26, 2013 | 01:07 PM
lazlong's Avatar
Default Re: 2002 Honda Accord Water Problem.
Do you live in a humid climate? Do you leave the A/C system on outside air when you turn the car off? Try putting the A/C on re-circ and put a desiccant packet in there.
Old Oct 26, 2013 | 03:49 PM
professorman's Avatar
Do you have a sunroof?
Old Oct 26, 2013 | 07:16 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The water could be from the moonroof drain tube being clogged (if it rained) or the A/C evaporator drain tube being clogged (if you recently used the A/C).
Old Oct 27, 2013 | 09:28 AM
NicoAnn94's Avatar
Yes I have a sunroof, I live in Newfoundland so it tends to rain often. Is there any ways to check to see if the A/C evaporator drain tube is clogged?
Old Oct 30, 2013 | 02:51 PM
Lost Again's Avatar
I'm with "tech" - moonroof drains (4 in all).
The AC drain would never get the seat wet......pass side floor, yes.
To answer the question.....there are several ways people go about "cleaning" the drains. For the AC drain, a piece of weedeater line and a shop vac (set to wet) work great for me. As for the moonroof drains - if you don't want to pull the front innder fender or mess around under the rear bumber cover....the same weedeater line works.
yazzd
Jan 3, 2017 11:08 PM
rraju
Mar 9, 2015 01:11 AM
thekid2390
Jun 30, 2013 12:15 PM
Cody_754
Aug 28, 2011 08:01 AM
marrieda97accord
Jul 6, 2008 12:06 PM
