Accord CD6 Ball Joints keep Breaking
Old Oct 25, 2013 | 01:25 PM
culprit00's Avatar
Default Accord CD6 Ball Joints keep Breaking
Hi Guys been having this problem with me CD6, its has happened like 5 times over the past 3 years where ill be driving and the balljoint just snaps it only happens on the passenger side, this is becoming quite annoying any way I can fix this?
Old Oct 25, 2013 | 02:03 PM
accordhybrid's Avatar
Default Re: Accord CD6 Ball Joints keep Breaking
Which one? Uppper? Lower? Tie Rod?
Old Oct 26, 2013 | 06:30 AM
culprit00's Avatar
the lower ball joint.. the one that sits just below the brake rotor
Old Oct 26, 2013 | 07:58 AM
ej7attack's Avatar
how does the rest of your suspension on that side look?
are you replacing this yourself or is a shop doing it.
what kind of parts you getting. remember, you get what you pay for.
the lower control arm ball joint socket wallered out?
these are all questions to ask yourself.
if I am not mistaken even Honda genuine lbj are quite cheap.
Old Oct 26, 2013 | 09:29 AM
MAD_MIKE's Avatar
MM Gruppe B
Albeit whomever is installing the lower ball joint is not installing the Circlip.
Pictures would be helpful of the LBJ, broken in situ, and after removal.
Old Oct 27, 2013 | 07:00 AM
culprit00's Avatar
Qej7attack...what quality brand should I go with, I may not live through another balljoint breakage..
@Mad_Mike.. the circlips were installed and it normally breaks from the thread the bolt screws onto
Old Oct 27, 2013 | 02:07 PM
MAD_MIKE's Avatar
MM Gruppe B
Is the base of the balljoint loose inside the knuckle?
Is the mechanic properly torquing the lower BJ stud? It should be 40lb-ft. Are they using the cotter pin? If the lower control arms taper is worn or damaged the stud may have a bending load being placed on it.
If you can take some pictures of the broken ball joint in situ that would be helpful.
Check the other lower control arm bushings and the front radius arm is not damaged or the bushings are not worn/missing.
Old Oct 28, 2013 | 02:06 PM
culprit00's Avatar
I don't have the busted balljoint anymore, but as for the pics ill upload em tomorrow.. I have another problem as well but ill make another post
Old May 14, 2014 | 04:12 AM
davemw's Avatar
Did you ever solve this problem? I just had the lower ball joint break on my 2000 accord. It seemed fine last week when I replaced the wheel bearing. The stud had broken off right at the ball. Want to make sure something else isn't bad. Will be replacing upper and lower on both sides after that scare!
Old May 16, 2014 | 11:21 AM
MAD_MIKE's Avatar
MM Gruppe B
If the break occurred after some work then I would suspect an incorrect procedure was used to dismantle or reassemble the parts.
However, if your wheel bearings are worn, then the lower balljoint should also be replaced as it is worn as well.
I replace both wheel bearings at the same time along with the lower balljoints.
skhell
May 11, 2016 09:57 PM
NMJimCRV
Honda CR-V & Element
Oct 13, 2014 08:30 PM
Big Jack Earl
Jul 6, 2009 10:01 PM
Adam_F123
Apr 19, 2004 04:30 PM
