FS: '91 Civic LX Sedan SiR LSD - IL $5,500
Old Oct 24, 2013 | 08:17 PM
grannyEK's Avatar
Default FS: '91 Civic LX Sedan SiR LSD - IL $3,900
1991 Honda Civic Sedan LX $3,900 obo
SiR B16a with Y1 LSD - NO CEL
190,000mi on chassis
Power Windows, Locks, Mirrors & Cruise Control
NO A/C or P/S
There are NO Check Engine Lights, everything was professionally installed, wired correctly, and no short cuts were taken. It does not leak/drip/burn any fluids including oil. The current wheels are from a '92 Integra GS-R with about 40% tread on tires. Mechanically 80-90% of this car has been replaced (motor, trans, brakes, suspension, steering)
Below is a list of the parts I have updated/upgraded/replaced within the last year. I have most all receipts.
Motor/Transmission:
Hmotors Online Sourced: JDM B16A Longblock, Y1 LSD Transmission, PW0 ECU obd0
GM Syncromesh FM trans fluid
Mobil 1 5w30 synthetic oil
HAsport Billet Motor Mounts
Exedy OEM Clutch
Exedy Lightweight Flywheel
Skunk2 Short Throw Shifter
NGK Spark Plugs and Wires
Distributor
Gates Racing Timing Belt
OEM Tensioner Pulley
OEM Water Pump
OEM Integra Radiator / Hoses
Suspension/Brakes, 4 wheel alignment was done after suspension work:
Energy Suspensions FULL Polyurethane bushing kit - black
Function Form Type 1 full coilovers
Blox rear Lower Control Arms
'91 CRX Si Rear trailing arms (Rear Disc Brake Conversion)
'90 Integra Sedan E-brake cable
Goodridge Stainless Braided Brake Lines
'90 Integra Front sway bar
(2) MOOG Lower ball joints
(2) Timken Front Wheel Bearings
(1) OEM Honda Front Driver Spindle with studs
(2) MOOG Outer Tie Rods
(1) Timken Rear Driver wheel bearing/hub assembly
(2) Rear Brake Calipers
New Brake rotors/pads at all corners
'90 Integra 40/40 Brake Prop Valve
Misc:
Sony Explode MP3 headunit with AUX input
Sony 6.5" Front/Rear speakers
Old Oct 24, 2013 | 08:36 PM
variable's Avatar
Default Re: FS: '91 Civic LX Sedan SiR LSD - IL $5,500
Great price
Old Oct 25, 2013 | 01:35 PM
grannyEK's Avatar
bump
Old Oct 25, 2013 | 01:51 PM
maxwellmercer's Avatar
Originally Posted by variable
Great price
Really? I'm not doubting the reliability of the car but, there is some hefty rust here.
Old Oct 25, 2013 | 02:37 PM
crx6662's Avatar
does seam pretty steep for a basic swapped ef. i probably wont even get $5,500 for my del sol lol
Old Oct 25, 2013 | 02:38 PM
grannyEK's Avatar
it's all good...thx for the bumps
Old Jun 6, 2014 | 03:02 PM
grannyEK's Avatar
Lowered Price
$3,900
Old Jun 7, 2014 | 10:45 AM
grannyEK's Avatar
bump
$3,900
Old Jun 8, 2014 | 05:08 AM
morganm58's Avatar
is it a first gen b16a?
Old Jun 9, 2014 | 01:50 PM
grannyEK's Avatar
1st gen B16A obd0
Old Jun 9, 2014 | 07:59 PM
grannyEK's Avatar
ttt
Old Jun 12, 2014 | 07:10 PM
grannyEK's Avatar
up
Old Jun 19, 2014 | 06:03 PM
grannyEK's Avatar
bump
grannyEK
Jun 19, 2014 06:04 PM
Rishiras
Oct 20, 2009 02:28 PM
