LS-V(b20v) Build Opinions
Ok guys ive been going about buying parts for my build and would like to know some of your opinions.
b18a1 block with a b20 crank
type r water/oil pump
acl race bearings
gates tension-er pulley
Supertech 12:5:1 Pistons (81MM)
Micropolished crank/knife edged
arp rod bolts
z10 block girdle
lsv dowel pins
Supertech valvetrain
Hondata IM gasket
skunk2 tuner 3's
skunk2 2nd gen intake mani w/ velocity stack 3' matched
ARP Headstuds
Buddy club 2layer head gasket
440' injectors w/AEM fuel rail
i know im missing a couple things but cant think of the top of my head right now.
Let me know all ya'll opinions.
Looking to get around 220whp on e85.
acl race bearings
arp rod bolts
z10 block girdle
lsv dowel pins
Hondata IM gasket
skunk2 tuner 3's
ARP Headstuds
I would get some pro 2 cams or m22 cams. Rocket is offering a great deal on those by the way. I'd go with RDX injectors too. Get in contact with a member on the forum named "slow sleeper" very helpful guy.
B20 crank is the same as B18a
Those cams are too big
Type R water/oil pump is the same as any VTEC
82mm would be a better idea than 81mm
You don't want to knife edge a crank unless you are road racing
You don't want to run a 2 layer headgasket, that's what decking and milling are for
There's better choices than supertech pistons
440 injectors sound huge for that setup
You won't see anywhere near 220whp unless you're at Church's
Check out my build for ideas, it's a B20V but you will get a decent idea. I just picked up a set of M22x's which would fit nicely in your setup as well.
any b series vtec head is good on any lsv build. But if your going for a build like the one i am shooting for it doesnt even matter what head your using. Ports are gonna be ports..
ALLMOTOR_EK
Feb 7, 2008 07:36 PM
