92 accord starting problems
I have a 92 accord, here recently the Rpms have been jumping around and the car will stall sometimes. I've cleaned the throttlebody, and I've put new spark plugs and wires. Now the car stalled on me and won't start. It will crank but just won't come on. Is there anything I can check myself to troubleshoot the problem? Thanks in advance and this seems like a great forum.
When combined with the tachometer going nuts the cause is usually the ignitor being bad. Swap it out with one from the junkyard(or even a whole distributor) and see if that fixes it. The '92 and '93 accords use the same distributor as you.
