skunk2 tuner stage 3 help
Old Oct 23, 2013 | 05:32 AM
dc2-millano-red's Avatar
Default skunk2 tuner stage 3 help
Thinking of getting skunk2 tuner stage 3 cams for my Dc2r
Which pistons would i be best off using for these cams
Wiseco 11.8:1 - 12.25:1
Wiseco 12.5:1 - 13.2:1
Car has neptune ecu
Decked Block 0.001
Toda exhaust mani
Custom 3" exhaust from mani back
Velocity stack with filter
Cold Air Feed
Supertech Valvesprings Retainers
Adj Cam Gears
ARP Head + Rod studs
Are these cams to much for this setup would i be best off going with tuner 2s
Any other cam/setup recommendations welcome
Old Oct 24, 2013 | 07:26 PM
KeeganBuilt's Avatar
Default Re: skunk2 tuner stage 3 help
Car has neptune ecu
Decked Block 0.001
Toda exhaust mani
Cold Air Feed
Adj Cam Gears
Wiseco 12:5:1
this is the proper ratio you should run. And if you wanna bump the comp up some more run a thinner head gasket or mill your head down.
Make sure your supertech springs are the SPR-H100DR(springs w/retainers)
Pro series(skunk2):
Springs rate: open-80lbs
Springs rate: seat-226lbs
Supertech(SPR-H100DR)
spring rate: open: 85lbs
spring rate: seat: 266lbs
You will run these fine. Please make sure that if you are building this motor yourself your piston to valve specs are good. Wiseco makes forged pistons so they expand so specs are diffrent from cast.
Hope this helps!
Old Oct 24, 2013 | 07:30 PM
UncleD's Avatar
Is this a B16a, B16b, B17, GSR, Ls/Vtec, B18c/5, B20 Vtec? Any headwork? You having Neptune - are you going to have it tuned? What octane of fuel will you be using?
Old Oct 24, 2013 | 07:53 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Bigger is not always better.
Tbone made 20 MORE hp switching from a stage 3 profile to a stage 2. This was on a 13:1 2 liter.
Old Oct 24, 2013 | 10:50 PM
Thanks for the advice.
Its a b18c jdm type r.No head work.Will have it tuned straight after the build and will be running on 95 ron.With that octane could be risky runing the higher compression of the wiesco pistons.
Thinking now my best option could be the tuner 2s as anything bigger could be over camming.
Will aso run eagle rods with the pistons and thinking of going with supertec valves and rdx injectors
Old Oct 25, 2013 | 04:06 AM
highboostcivic's Avatar
Get tuner2's and you will never look back...
Old Oct 25, 2013 | 11:02 AM
2LEM1's Avatar
I like to party
Community Builder
+1 on Tuner 2s, or BC IVs.
(The BC4 will give you a bit more midrange, both cams will have the same high lobe)
Old Oct 25, 2013 | 12:03 PM
UncleD's Avatar
95 octane? I'd go with the bigger compression and:
sh4k3r
Jan 16, 2011 07:09 PM
c17r15
Nov 22, 2004 02:42 PM
sleepN
May 14, 2004 04:27 PM
