Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 Odyssey EX - Drive Shaft Replacement
Old Oct 22, 2013 | 11:51 AM
kknh3's Avatar
Default 2001 Odyssey EX - Drive Shaft Replacement
One of the CV boots on the driver's side drive shaft is split and throwing grease. I need to replace it, but I've heard that it can be difficult to get the old axle out due to a sagging clip/ring on the differential end of the shaft.
Has anyone done this job themselves? If so, can you provide some guidance, hints, or other input?
Old Oct 25, 2013 | 08:30 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2001 Odyssey EX - Drive Shaft Replacement
If the circlip is holding on pretty good, rotate the axle 180° and try prying it out again. If it is still difficult rotate 90° and try again, if it is still being a PITA to remove rotate 180° again and it should pop out. Being the circlip is a C shape with an open end, of one of the ends does not retract it can become a right mother to remove. It will pop out with a bit of force but it should not be a struggle. If there is a lot of resistant do not force it, as you may bend the circlip. It just needs a quick jerk to overcome the spring pressure of the circlip to compress and pop out.
I usually use a flat bar and a quick pull to pop the axle out of the differential housing.
B_Swapped93
Dec 21, 2013 10:48 AM
Burlyirishdude
Apr 23, 2006 10:28 AM
07734
Dec 1, 2004 06:51 PM
mickey513
Feb 5, 2003 06:14 AM
-CP-
Jan 21, 2003 08:07 AM
