B18c1 with usdm type r pistons has a code 21 but vtec works fine
Old Oct 22, 2013 | 09:58 AM
Eg.ls.turbo's Avatar
Default B18c1 with usdm type r pistons has a code 21 but vtec works fine
Just as the title says. Code 21 and 43. Code 21 I know is the vtec solenoid, but the cars drives fine and vtec hits strong. I've reset it once before and the code pops up again.
As for the code 43, I know it's the fuel pressure but I have a adjustable fuel pressure regulator so that's probably y it's on? Not so sure on that though.
Other words car runs strong even though those codes are up. The engine light does not stay on during driving. Mayb it's the chip I got?
Old Oct 22, 2013 | 03:22 PM
B_Swapped93's Avatar
Default Re: B18c1 with usdm type r pistons has a code 21 but vtec works fine
remove "chip" and see where did you get this chip from ?
Old Oct 22, 2013 | 08:40 PM
The chip I ordered is from phearable. You think it's the chip?
Old Oct 22, 2013 | 11:34 PM
Solster's Avatar
i have a virgin ECU thowing code 43 and 22
code 22 turned out to be a leak at the Vtec mounting gasket.
as for the code 43 i have search ALOT and turns out the most common fix is a new Disty or 02 Sensor. i have also had 3 hondas with adjustable FPR's and Non of them ever had code 43.
Old Oct 23, 2013 | 06:26 AM
Ok ill check on that
Old Oct 23, 2013 | 06:27 AM
Also could a leak near the o2 cause a code 43? I have a aem wideband in place of the o2 sensot
racingant
Aug 12, 2005 05:12 PM
brian2903
May 2, 2004 02:46 PM
Audipwr1
Jun 30, 2002 07:07 PM
