F22A6 build
I wanted to build my motor but i honestly don't know where to start, i've done a full 2.5 stainless steel exhaust and a cold air intake. I want to do something to the car that will actually make a difference any advice?
What is your budget and what are your goals? You have to set both of these before you go into any sort of build.
Are you wanting to keep it naturally aspirated or looking to build for forced induction?
Intake manifold & throttle body upgrade
Carbs or individual throttle bodies
turbo
Camshaft
Cam gear
Valve springs and retainers
Valves
Valve job
Maybe some cylinder head port work
Forged Pistons
Injectors
Adjustable fuel pressure regulator
An EMS and a tune!
If you haven't upgraded your suspension or brakes for more power I would start there!
Stick around for a while and check the FAQ. There are lots of F series builds putting down everything from a mild 150whp N/A build to a 600whp boosted build.
turbo
Camshaft
Cam gear
Valves
Valve job
Forged Pistons
Injectors
An EMS and a tune!
