IL F/S or F/T 1992 spd eg8
Old Oct 21, 2013 | 02:55 PM
94IntegraRS's Avatar
Default IL F/S or F/T 1992 spd eg8
Contact: 217-717-5529
Hello, I am looking to trade my 1992 Honda Civic sedan for another project, or sell for $1500 obo. The vehicles that I am interested in are ________ and must be 5 speed.
1990-1993 Honda accord wagon
1993-1997 Honda Del sol
1995-1998 Honda odessey (I dont think they make these with manual transmissions which is fine lol)
1988-1991 Honda civic sedan
2003-2009 Honda Ruckus (50cc-150cc)
The civic has a D15B7 with 5 spd tranny. It has 165,242 miles. (Its a project car and DOES RUN & DRIVE)
Ill start off by indicating the bad about it:
previous owner I believe had plans on auto xing the vehicle so all rear interior has been removed, I have a spare rear seat out of a ej coupe and installed it,but it is a little to short on each side. Also it has the typical honda rust on both rear quarters,but its a little rough,but can be fixed . It doesnt have a the adapter piece for the radio, but you can go to the junk yard and take that out of any civic to replace. No a/c or power steering. The last bad thing about it is that the driver side inner door opener is broken so you have to roll down the window to open door while inside.
Now for the goods:
- It has an Spectre short ram intake system
- no name cat back exhaust system
- no name header
- no name adjustable cam gear
- Front end has been lowered 3 1/2 on no name coil over sleeves, while the rear is stock?
- Aftermarket ichibahn steering wheel
- has all 4 door visors, and rear window visor
- I have a d16Y8 head for it, but it need head bolts. I had plan on doing a mini me build. Also it has a new vtec solenoid.
- I also have a disc brake conversion for it, but only things missing for the conversion are caliper and brake pads (90 crx si)
- If its to my liking I will put on my black set of LS meshies
- Clean and clear title in hand!
- NGK spark plugs, and spark plug wires
- New valve cover gasket w/spark plug garments
- I can also give a dual 12 inch sub in box with a dual 400 watt amp
Will have updated pictures tomorrow of the engine bay (with the new wires) and on the ls meshies.
94IntegraRS
Oct 19, 2013 07:24 PM
onecleanDA
Northern California (Sales)
12
Jan 21, 2008 08:03 AM
