JDM CRX SiR exploded part view
Does anyone have a link to the Helms manual (or whatever it is called in Japan) that shows the exploded view of the front end of an SiR? Or better yet, the exploded view from the parts department. I need to see the assembly and get part numbers. Thanks.
Not sure if any of these will help. I don't think they are in production of these parts still.
You can find a regular assembly from here in the US and try and piece together stuff the best you can. But I doubt you'll find the SiR JDM one.
http://www.hondaautomotiveparts.com/...FRONT+BULKHEAD
http://www.hondaautomotiveparts.com/...5=FRONT+FENDER
http://www.hondaautomotiveparts.com/...RONT+LOWER+ARM
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
choose Ref nr Part Number Part Description Qty
01 68100-SH2-306ZZ TAILGATE COMP. 1
02 68210-SH2-S00ZZ HINGE COMP., TAILGATE 2
03 68214-SH2-000 SHIM, TAILGATE HINGE N
04 68217-SH2-S00 SEAL, TAILGATE HINGE 1
05 71700-SH2-000ZA SPOILER COMP., TRUNK *NH512Z*
(POLAR WHITE-Z ) 1
06 73205-SH2-A00 GLASS ASSY., EXTRA WINDSHIELD 1
07 73219-693-951 SEAL, FUEL LID OPENER 1
08 73256-SH2-003 MOLDING COMP., EXTRA
WINDSHIELD 1
09 73257-SH2-003 MOLDING SUB ASSY., EXTRA
WINDSHIELD LOWER 1
10 73258-SH2-003 SEAL, TAILGATE EXTRA
WINDSHIELD UPPER MOLDING 1
11 73265-SH2-003 END, R. EXTRA WINDSHIELD LOWER 1
12 73270-SH2-003 END, L. EXTRA WINDSHIELD LOWER 1
13 74411-SH2-003 CABLE, FUEL LID OPENER 1
14 74800-SH2-003 LOCK ASSY., TAILGATE 1
15 74811-SH2-003 ROD, TAILGATE LOCK 1
16 74812-SH2-043 CYLINDER, TAILGATE 1
17 74820-SH2-960 STAY ASSY., TAILGATE OPEN 2
18 74827-SH2-003 STOPPER, TAILGATE 2
19 74829-SH2-000 COVER, OPEN STAY END 2
20 74830-SH2-003 CABLE, TAILGATE OPENER 1
21 74881-SK7-003ZA COVER, TAILGATE OPENER
*NH167L*
(GRAPHITE BLACK ) 1
22 74882-SH3-003 OPENER ASSY., TAILGATE
23 74882-SK7-003ZA OPENER ASSY., TAILGATE
*NH167L*
(GRAPHITE BLACK ) 1
24 75550-SH2-004 GARNISH ASSY., R. EXTRA
WINDSHIELD SIDE 1
25 75551-SH2-005 CLIP, EXTRA WINDSHIELD SIDE
26 75555-SH2-J00 GARNISH ASSY., L. EXTRA
WINDSHIELD SIDE 1
27 75556-605-010 BOLT, LOCK STRIKER
28 83305-SD2-003 STRIKER, TAILGATE
29 83307-SD2-000 SHIM, TAILGATE STRIKER (2.0) N
31 85511-SB2-003ZQ **** ASSY., FUEL OPENER
*NH167L*
(GRAPHITE BLACK ) 1
32 85512-SB2-003ZN **** ASSY., TAILGATE OPENER
*NH167L*
(GRAPHITE BLACK ) 1
33 90103-SH2-000 BOLT, TAILGATE OPENER STAY,
10MM 2
34 90106-SD5-000 BOLT-WASHER, 6X16 4
35 90301-SH2-003 NUT, SPECIAL, 4MM 2
36 90303-SB0-000 NUT, CAP, 6MM 2
37 90501-SH3-000 PACKING, SEAT 1
38 90653-SH2-000 CLIP, TAILGATE SPOILER 2
39 90653-SK7-003 CLIP, TAILGATE SPOILER 1
40 90654-SA4-003 CLIP, WIRE HARNESS, 6MM
(WHITE) 1
41 90691-SC5-003 CLIP A, OPENER CABLE 2
42 91502-SH2-003 CLIP, TAILGATE EXTRA GLASS 2
43 91506-SH3-003 CLIP, OPENER CABLE SIDE 1
44 91601-SH2-003 GROMMET, TAILGATE EXTRA LOWER
MOLDING 2
45 91610-SH2-003 SPACER, TAILGATE EXTRA LOWER
MOULDING 1
46 91613-SH2-000 SPACER, EXTRA WINDSHIELD LOWER 1
47 93492-06012-08 BOLT-WASHER, 6X12 2
48 93492-06020-08 BOLT-WASHER, 6X20 1
49 93600-06016-1A SCREW, FLAT, 6X16 3
50 93903-14180 SCREW, TAPPING, 4X8 1
51 94071-08080 NUT-WASHER, 8MM 4
52 95550-15000 PLUG, BLIND, 15MM 4
53 74820-SH2-306 STAY SET, TAILGATE OPEN 2
choose Ref nr Part Number Part Description quantity
01 68100-SH2-971ZZ TAILGATE COMP. (1)
(GLASS ROOF)
05 71700-SH2-000ZA SPOILER COMP., TRUNK *NH512Z* 1
POLAR WHITE-Z
05 71700-SH2-000ZB SPOILER COMP., TRUNK *NH95M* 1
BLADE SILVER METALLIC
05 71700-SH2-000ZC SPOILER COMP., TRUNK *NH526M* 1
FLINT BLACK METALLIC
05 71700-SH2-000ZD SPOILER COMP., TRUNK *NH537M* 1
PEWTER GRAY METALLIC
05 71700-SH2-000ZE SPOILER COMP., TRUNK *R72P* 1
TORINO RED PEARL
29 83307-SD2-900 SHIM, TAILGATE STRIKER (1.0) N
(POLAR WHITE-Z ) 1
WINDSHIELD 1
WINDSHIELD LOWER 1
*NH167L*
(GRAPHITE BLACK ) 1
*NH167L*
(GRAPHITE BLACK ) 1
WINDSHIELD SIDE 1
WINDSHIELD SIDE 1
*NH167L*
(GRAPHITE BLACK ) 1
*NH167L*
(GRAPHITE BLACK ) 1
10MM 2
(WHITE) 1
MOLDING 2
MOULDING 1
(GLASS ROOF)
POLAR WHITE-Z
TORINO RED PEARL
I need help with the brackets around the headlights. I think I'm missing parts since they are significantly different than the US headlights.
Do they look hard to fabricate? I'm no JDM genius. You can always bend some metal and drill holes to make some custom mounts and such. I've done that before. Getting JDM head light brackets is going to be tough. More so if you aren't getting the head lights at the same time. It'd be hard to find someone selling just the brackets, ya know?
The headlights bolt up like stock as long as you have an oversea's 90+ front end hood and front bumper. I know the bottom of the headlight assembly have a little L bracket, is thatwhat you are asking?
USDM http://www.hondapartsnow.com/Page_Pr...5997%201475063
JDM http://www.crxsi.com/jdm/ef8-1005225...-Headlight.htm
28 and 35 are the USDM equivalent of JDM parts 4 and 8
sounds like your best bet is going to be the junk yard.
you should be able to pull them off of any of the vehicles listed on this page:
http://www.hondapartsnow.com/genuine...0-SH3-A00.html
Kato7997
12
Feb 5, 2003 05:47 AM
