B18a1 idle problem
Old Oct 20, 2013 | 10:26 PM
Loccdog's Avatar
Icon6 B18a1 idle problem
Hey guys I have a 88 Ef sedan with a ls and every time I go to drive it in the morning I have to hold the gas for a few min until its warm to keep itself on or else it just starts for a sec and it dies. i have tried adjusting the throttle cable but once its warmed up it revs too high. I hate it because sometimes when I'm driving and I push in the clutch and it dies I was wondering if anyone could help me figure out why it does that? Any help is greatly appreciated.
I can work on it I just tend not to tear into things I don't know for the fear of screwing something up.
Old Oct 20, 2013 | 11:53 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: B18a1 idle problem
Does your tb have a fitv? Does the iacv work?
Old Oct 21, 2013 | 02:45 AM
Freemananana's Avatar
These are the best bets for your idle issue. Check the FAQs on this forum here.
Old Oct 23, 2013 | 03:41 PM
Loccdog's Avatar
It's non fitv
How do I check of it works?
Old Oct 24, 2013 | 03:03 AM
Originally Posted by Loccdog
It's non fitv
If it works? The IACV? The idle air control valve should be on the drivers side or back of the manifold.
Credit to the author: https://honda-tech.com/newreply.php?...ply&p=20876482
Originally Posted by wildoutwhitegsr
The function of the IACV a.k.a. Idle Air Control Valve is to adjust the idle based upon the amount of air entering the engine, then the computer reacts to this information by adjusting the cars rpm.
Reasons why you should take it apart and clean it:
-High idle after your car warms up
-Lumpy idle
-Roaming idle
-Hunting idle
-Fluctuating idle
Tools Needed:
Ratchet
12mm Socket
Pliers
Brake Cleaner or Simple Green
Paper Towels
A cooled down engine for at least 2 hours
1) Now you got to locate where the IACV is, pop your hood and it’s located directly behind the intake manifold. It’s actually connected to it. Remove your intake and strut tower bar. (If applicable)
2) Place a couple of rags underneath to catch the coolant spill. Loosen the two hoses running to the IACV with your pliers by squeezing the two clips and moving them away from the end, circled in yellow. DO NOT cut the hoses as they are the exact length and you will have to buy new ones if you do.
3) After doing that remove the harness connected to the IACV on the driver side, circle in blue.
4) Then to finally remove it from the intake manifold, remove the two 12mm bolts, circled in red.
Now that the IACV is removed from the intake manifold make sure that you do not lose the rubber gasket as you need this so that it does not leak after you re-install the IACV.
5) Take your brake cleaner or simple green and start to clean up the inside of the IACV by spray inside the two holes. Continue to do this until no more dirty fluid comes out. Should take anywhere from 5 minutes to 15 minutes. This depending on how old and dirty your IACV is. The gasket can be seen in this picture as well.
6) Once you’re done cleaning out the IACV let it air dry. I let it air out for 20 minutes while I did other maintenance on the car.
Now your ready to re-install it back on the car so follow the steps backwards from 5 – 2
Good Luck
Old Oct 24, 2013 | 06:49 AM
Loccdog's Avatar
Yeah I took it off cleaned it out with brake fluid an out it back on I adjusted the idle screw Aswell it started and idled good yesterday but I will see later today when I get back home if it will start good completely cold.
Old Oct 24, 2013 | 06:57 AM
Shouldn't be any different since you don't have a FITV. So the cleaning fixed it for you?
Old Oct 26, 2013 | 12:06 AM
Loccdog's Avatar
Not completely it still dies for a sec I have to hold the gas and it can stay one after about 2 min but it idles pretty rough when I don't give it gas
Old Oct 26, 2013 | 03:11 PM
Hmmmm~ A low idle. I can't remember what causes that. It sort of stalls? When you give it gas, what does it idle at?
Old Oct 26, 2013 | 10:51 PM
Loccdog's Avatar
It shakes more than usual i can actually feel it on my steering wheel pretty good.
As for the idle I don't know my cluster doesn't show the rpms
Old Oct 28, 2013 | 05:16 AM
Check for an engine misfire. Remove one of the spark plug wires and listen for engine RPM drop. Then move to the next.
Old Oct 30, 2013 | 10:36 PM
Loccdog's Avatar
Will the rpms not drop if its misfiring?
Old Oct 31, 2013 | 05:09 AM
Unplug your idle air control valve and try it. The car will be a mess if it's misfiring. The idle air control valve will just dump a bunch of air and run the idle all over the place if there is a misfire.
20vt_gtx
14
Dec 27, 2019 04:50 AM
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
jdm4drSi
Apr 6, 2007 08:19 AM
SWC
Apr 3, 2006 08:13 PM
chirp2hrd
Oct 13, 2002 01:36 AM
