01 integra pulls hard right lowered?
I have an 01 integra that is lowered by springs, and it pulls hard to the right do i need a camber kit, or new lower control arms if so what kind do i need?
You need a wheel alignment, I would also look for something bent, an alignment shop will find if something is bent.
You should not need a camber kit, unless the drop is extreme, the drop itself will not make the car pull to one side or the other, unless something else is wrong. 94
tire wear more depends on how you drive.
I got a f/r camber kit but not for better tire wear, negative camber helps in the corners
if anything i've worn my tires even worse from it lo
Ep3-4-EVA
Nov 15, 2003 05:10 PM
