Rear Side Panel Rust
Old Oct 20, 2013 | 05:36 PM
Cody Pereira's Avatar
Icon2 Rear Side Panel Rust
Hey everybody,
So I started a full rebuild on my '95 Del Sol Si, fixing the body work that needed repair over time. I have the rear panel rust (on the panel "leg" between the wheel well and the door) as well as a small piece just above where the rear bumper meets the sheet metal on the wheel well. I can imagine that the rusted areas need to be cut out and a new piece welded in but my question to the HT forum is where can I find these replacement panel sections? Not necessarily looking for the entire panel... just the sections that are affected. I figured this wasnt a shot in the dark as these areas are commonly destroyed by rust...
Thanks for the help in advance, im sure someone has some helpful info.
Old Oct 20, 2013 | 06:38 PM
boostlsveg's Avatar
Default Re: Rear Side Panel Rust
Go to the junkyard.. If u find with the piece u need undamaged im sure they'll cut out however much u want. N for the cheap most of the time
Jose Berbere
Dec 28, 2017 08:52 PM
Preludedood
Jan 20, 2013 09:05 AM
James
Feb 7, 2005 04:47 PM
91bentcrx
13
Oct 12, 2004 06:56 AM
