OBD2 Scanner Q
Once you use the erase codes function that clears all the codes. They don't always come right back.
That code is for a leak detected in the EVAP system..... Have you done anything to the car lately. Like removed any components or vacuum lines?
P1457 is a two-trip code. Once cleared from the PCM, it cannot be reproduced in one drive cycle. Additional test drives may be required to reproduce all driving and ambient conditions required to set this code.
