cruise not working
Old Oct 20, 2013 | 07:31 AM
Bhguog2's Avatar
Icon2 cruise not working
I am looking for help regarding my cruise not working on a 1992 accord EX. initial self check when starting does not illuminate cruise as before. Push button for cruise lights up...but again dash light does not come on and of course cruise does not engage.
I have checked connections to actuator and replaced actuator electric module. All fuses check out. When I remove vacuum pressure is released. I am stumped...any ideas?
Old Oct 23, 2013 | 03:06 PM
Lost Again's Avatar
Default Re: cruise not working
Auto or manual? Any stored codes in the ECU/TCU?
Did it work at anytime before? Any recent work done?
Old Oct 28, 2013 | 08:12 AM
Bhguog2's Avatar
It is an automatic and yes there has been a lot of work done lately...all motor mounts replaced...driver side lock mechanism replaced...left daytime running light...the breaks were staying on and the plastic piece that depresses the small button was changed...went back and checked all electric connections....used elec contact cleaner....no luck still...thx for help
Old Oct 29, 2013 | 03:10 PM
Lost Again's Avatar
If the cruise was working before and someone replaced the "brake light" stopper....there is the answer to your question. My guess, they didn't do it the proper way - BUY the dang plug from the dealer and call it a day. I'll bet they did the cheap way and "stuck something" in there.
Which means the brake light switch it now out of adjustment no allowing the cruise to work. Either get a proper repair or adjust the brake light switch so that it is FULLY closed (yes the brake lights can be off but the switch is not closed enough for the cruise to work).
Old Oct 30, 2013 | 04:07 AM
Bhguog2's Avatar
Wow I will go to the dealer and get the right part....yes I stuck something in there to get the lights to turn off!
Old Oct 30, 2013 | 02:03 PM
holmesnmanny's Avatar
oreilly sells the piece too
http://www.oreillyauto.com/site/c/se...ord&vi=1365397
Old Oct 30, 2013 | 02:23 PM
Lost Again's Avatar
Sorry.....my response was worded that way, again my bad and sorry for the way it sounded.
The "plug" (OE PN 46505-SA5-000 - verify) from the dealer is ~$2.25. If the "fix" you put in is a good one, you can adjust the brake light switch so that it fully closes, you'll need a voltmeter to confirm continuity on the proper two pins of the switch.
Old Oct 30, 2013 | 05:14 PM
Bhguog2's Avatar
It worked...thanks for your help guys. Lesson learned.
Old Nov 2, 2013 | 09:17 AM
Lost Again's Avatar
Nice to have cruise again
Old Nov 4, 2013 | 12:27 PM
Taybrill's Avatar
I'm having the same problem. Push the cruise button and the light turns on (on the cruise button), but the light on the dash does not. It's not a fuse, so I'm not sure what to check next. It's a 96 accord.
supergodzilla
Jul 29, 2007 07:27 PM
Tu MaDre
Jan 15, 2007 09:27 AM
jam36a
Sep 20, 2006 12:58 PM
