Not Boosting after running too rich...?!
Old Oct 26, 2002 | 10:48 PM
Sipower99's Avatar
Default Not Boosting after running too rich...?!
Does anybody have any idea of why you would stop boosting after running too rich maybe?
here's the situation. 99 si w/ drag kit. running fine for three some months and then check engine light came on and finally after a week or so started idling funny and came to the point where every stop you make, the car would stale out.
finally saw the problem was primary O2 sensor from computer diagnose and saw that it was caked w/ carbon build up. Seeing that, cleaned the O2 sensor off and we changed the spark plugs too and saw that they were black w/ carbon build up also. after all that, started up the car, everything ok except now it won't boost.
any ideas or suggestions?
thanks for any help at all....
Old Oct 27, 2002 | 01:41 AM
MiraiZ's Avatar
Default Re: Not Boosting after running too rich...?! (Sipower99)
sounds like an exhaust leak...check carefully
Old Oct 27, 2002 | 07:28 PM
Mugen Dom's Avatar
Default Re: Not Boosting after running too rich...?! (MiraiZ)
how would it be an exhaust leak we would deffinatly see carbon coming out if there was an exhaust leak engine bay is very clean...(sorry if that sounds a little sarcastic) i opened his wastegate(deltagate) and the diaphram is not cracked or anything so im assuming its working properly havent had to much time to look at the car only an hour or so...some people here said to gap the plugs at .030 and after that the car would choke at WOT so i regapped it to stock .044 NGK vpower....hopefully my friend will let me have alot of time to trouble shoot but any ideas with what info u got drag3 kit vortec fmu inline pump t3t04e hks BOV and deltagate WG dont think theres an exhaust leak though i wanna see if maybe the WG is being retarded but gotta have more time damn school
Old Oct 27, 2002 | 10:06 PM
MiraiZ's Avatar
Default Re: Not Boosting after running too rich...?! (JdMB16Ahatch)
are you spooling at all?
Look for the obvious first...not being able to boost usually means
a) not enough exhaust pressure (leaks)
b) leak in somewhere between compressor and throttle-body
Look carefully! I have had some folks swear that they've checked and re-checked, only to find that its something very simple and obvious. Make sure that your WG is down tight, and that the exhaust mani is on tight...using your eyes is sometimes a mistake....use your ears and nose to find small leaks.
Check all your IC pipes carefully! (connectors and clamps etc...)
Finally, if you have done all this and STILL can't find any problems...check the hard stuff..make sure the compressor wheel spins...etc... Let us know what"s up..!Good luck!
HondamakesS2000
Engine Management and Tuning
Oct 17, 2009 11:44 AM
55Division
Jul 5, 2006 07:28 PM
hondaracin24
Mar 25, 2005 06:55 PM
Mr. Softee
Jul 6, 2002 08:47 PM
GruvyTune
Nov 27, 2001 06:10 AM
