Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda civic 2002 heater/ A/C not blowing hot or cold air
Old Oct 16, 2013 | 10:55 PM
vic_2002's Avatar
Default Honda civic 2002 heater/ A/C not blowing hot or cold air
My civic 2002 heater and a/c system is not blowing hot air or cold air. . Recently the engine has been replaced. After being replaced, I stopped getting cold air from the A/C. I was told that the compressor automatically shuts down if the freon is out. Is that something to consider with the A/C
Where would I start to diagnose the heater system? The blower and control systems all seem to work fine. Coolant levels are good.
Old Oct 17, 2013 | 01:05 PM
toyomatt84's Avatar
Sanji
Default Re: Honda civic 2002 heater/ A/C not blowing hot or cold air
You may have a clogged heater core, and unless you had the A/C system recharged... its not going to work either.
Old Oct 17, 2013 | 08:40 PM
vic_2002's Avatar
Can I just flush out the heater core with a water hose. I felt the heat on the hose going to the heater, will a clog reduce heat? And, will I detect debris in my coolant?
mlee19841
May 1, 2015 03:26 PM
Wrona
Nov 6, 2011 02:26 PM
kelviiv
Jan 25, 2008 01:55 AM
cascaritas
17
Sep 22, 2004 06:50 PM
