Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
oldschooling a 4 door
Old Oct 16, 2013 | 10:49 PM
charlee's Avatar
Default oldschooling a 4 door
thought id share an interesting swap. i have not been taking a lot of pictures of the work but you get the idea.. its not a build thread but i can answer some curiostiy questions
b20 automatic / built trans
04 civic
small turbo soon after its running
needs to stay automatic for the costumers wife to be able to drive it.
im still working on the wiring but its pretty straight forward.
only minor nicnacs are left for it to run.
its an inexpensive swap and simple. its done in a way that it will be able to pass the emissions plugin test under protocol iso 9141-2
pictures are in no specific order.
il post more as i go or any request
here is as it currently sits
auto transmission
overall engine space
firewall clearance
we used the d17 shift solenoids on the crv trans since they are angle up to clear the subframe. special adapter plate was used since solenoids used different bolt paterns. luckly for us they share the same resistance as the crv ones. looks like honda ran into space issues so they angled them up with the 01 and up civics
here is a pic right after we had the engine bolted up for the first time with just the side mounts
i got more pics coming. trans will be sent to get modified. line pressure and cooling system modifications.
Old Oct 17, 2013 | 12:08 AM
Gstizzle402's Avatar
Default Re: oldschooling a 4 door
What year model is this in? And you should pm me
Old Oct 17, 2013 | 01:07 PM
toyomatt84's Avatar
Sanji
That's pretty creative. However, it wouldn't be legal in California to do that swap.
Old Oct 21, 2013 | 05:40 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
It's not legal in any state!!! Motor must be same year or newer than chassis.
Old Oct 21, 2013 | 06:32 PM
wolfy47's Avatar
^^I want to agree because it seems like that would be the EPA law but I'm personally not 100%. If your smog readings are sent into the state its is doubtful it'll pass for the fact since the newer ECU's give out the make, year and model of the car being tested in the port test.
Old Oct 21, 2013 | 07:21 PM
toyomatt84's Avatar
Sanji
That's not technically true. Certain counties in Wisconsin have no ruling against this swap.
Old Oct 21, 2013 | 08:57 PM
wolfy47's Avatar
^^^EPA says otherwise (federal>state) and op's location looks to be arizona, also B20 is a SUV motor which may or may not play a role in making it "more" illegal, and Tier 2 cars were introduced in 2004 (which is another possibility of making it even "more" illegal).
http://www.epa.gov/compliance/resour.../engswitch.pdf
Old Oct 21, 2013 | 10:55 PM
It's on a federal level not state.
Old Oct 22, 2013 | 07:26 PM
toyomatt84's Avatar
Sanji
I suppose Federal levels were something I hadn't considered, however... I have seen some weird stuff out here.
efbastard
Feb 13, 2017 06:31 PM
deving916
14
Dec 4, 2010 08:16 AM
radicaled434
28
Dec 25, 2008 04:58 AM
benh
Apr 25, 2005 04:34 PM
