Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Civic LX gears shifting problem.
Old Oct 16, 2013 | 07:45 PM
april_q08's Avatar
Default 01 Civic LX gears shifting problem.
I have a 4 cyl. automatic 2001 honda civic lx with a rebuilt engine and a rebuilt transmission.
The problem is when I drive it, first gear does not shift until a little over 3,000 rpms, I don't know if this is normal for a recently rebuilt tranny.
Second gear shifts at about 2,200 rpms which seems fairly normal.
Can someone please help me out?
THANX!!
Old Oct 17, 2013 | 10:54 AM
lvmevo's Avatar
Default Re: 01 Civic LX gears shifting problem.
never noticed . but it sounds about normal to me. I just got a remanufactured trans also . next time I drive ill check and report back.
Old Oct 17, 2013 | 10:58 AM
april_q08's Avatar
Thank you!!
Old Oct 18, 2013 | 10:38 AM
lvmevo's Avatar
drove the car yesterday. i tried to make it shift at those points but in first if I put light pressure on the pedal like in a parking lot. it will shift early. like 2200 RPM so i would say yours not shifting until then is strange. I mean i can get it to shift at any given rpm by giving it gas till the desired rpm then it will shift, but definitely 3krpm is not the minimum rpm i can it to upshift. Not sure if it matters but mine is an 02 civic EX
Old Oct 21, 2013 | 07:26 PM
vic_2002's Avatar
I recently rebuilt my transmission for my civic 02, there is an upgrade for the transmission filter kit. The new one is twice the size. How much mileage have you put on the rebuild tranny. Have you checked your transmission fluid?
wushubrian
Feb 4, 2005 04:36 PM
wushubrian
Feb 4, 2005 02:23 PM
