Crx d16z6 fuel injectors?
Old Oct 16, 2013 | 10:24 AM
suburban_ninja's Avatar
Default Crx d16z6 fuel injectors?
Ok so I'm trying to get my options straight here for my swap. I'm converting my 90 crx to obd1 from obd0. I have a full z6. But my question is with the fuel injectors. Can I put my d16a6 obd0 injectors in the z6 rail and run it with stock wiring and the resistor box? Or do I have to do the other option and wire the obd1 injector plugs on my obd0 harness and do something about the resistor box? Thanks in advance.
Old Oct 16, 2013 | 04:20 PM
Red-Rocket's Avatar
Default Re: Crx d16z6 fuel injectors?
yes, your stock injectors will work just fine
Old Oct 16, 2013 | 06:53 PM
Ok thanks for the response. But on a side note would my other option have any gains? Or is that just another option if I didn't have the a6 injectors?
Old Oct 17, 2013 | 04:01 AM
Freemananana's Avatar
You can use the resister box and the A6 injectors or you can use the Z6 injecotrs and no box. There is no gains. It's just the type of injector. The ECU puts in a select amount of fuel, so there should be no difference between these two injectors.
Old Oct 17, 2013 | 03:04 PM
Sweet thanks. Guess ill use a6 injectors for ease of the build. Want to hack the least amount of wiring I can.
Old Oct 17, 2013 | 03:39 PM
Amen to that.
MastaFlyMason
Sep 3, 2017 10:06 AM
Chris1
Sep 3, 2008 10:29 AM
pinecone
Apr 25, 2006 06:41 AM
killa rex
Jan 25, 2006 02:54 AM
vtecrx
11
Sep 14, 2002 08:19 AM
