Car keeps cutting off. Please help me...
Today I started my car up went to work and work, when I come out for lunch my battery was dead after I changed it 3 weeks ago. I don't understand why my battery goes dead so often I have tested both battery alternator and starter everything comes back good. Then I leave work again that night, I start my car up to warm up and my car cuts off while warming up, had to turn the key a couple of times before it would start back up. What is going on with this vehicle after I fix one thing something else goes wrong. I have also changed my ignition coil twice and ignition control module twice as well. I even switched to the performance ignition coil. What am I doing wrong. Please help me...
Sounds like it could be a bad connection at the battery. Make sure the terminal ends are good and the ground is solid.
Could also be an issue with the ignition switch itself in the steering column.
Also if you have an aftermarket stereo (amps, subs etc.) if the electrical is not done right it can bleed a lot of power.
evoluti0n12
Jun 2, 2009 08:57 PM
udm_motorsport
Mar 26, 2004 10:11 AM
