Weird Spark Plug Wire Issue
Old Oct 15, 2013 | 07:15 AM
xSOHC's Avatar
Default Weird Spark Plug Wire Issue
So im pulling the plug wires out of my car and the coil of one of them tears off and is like attached to the spark plug. Ive tried pulling it off with pliers, no luck, tried using a flat head to pull it up, no luck. Any suggestions? Its just the plastic bottom part thats stuck, the wire came out when i went to pull it out. Thanks in advance
Old Oct 15, 2013 | 07:30 AM
CO671's Avatar
Default Re: Weird Spark Plug Wire Issue
Does it look like this
Sounds like the issue I had on my CRV.
If it does look like this, just get HUGE long-nose / needle-nose pliers. It's the only way I got them out.
Originally Posted by CO671
Old Oct 15, 2013 | 09:30 AM
Acemcguyver's Avatar
You can take a piece of stiff wire and bend a hook in the end to wiggle down along the sides and hook the rubber at the bottom and pull it out from the bottom. I have a broken PTO cable end that I've made into a tool just for this purpose, it works like a champ.
Old Oct 15, 2013 | 12:08 PM
Grade50's Avatar
10 Year Member
This is reason dielectric grease should be used.
PsXtreme
Jun 26, 2016 01:43 PM
thatasiankidtony
Aug 8, 2006 07:01 PM
drunkenmaster
Sep 2, 2004 04:00 PM
hondaeg8
11
Jul 29, 2004 10:37 PM
slowd16z6
Mar 13, 2004 07:12 PM
