CA DROWSPORT BUILT 2t RUCKUS!!
Honda Ruckus
Color: Honda's Cerulean Blue Metallic
Powdercoated Black:
Front Frame, Triple Tree, Gas Tank, Motor
WPC Treated: Pistons, Piston rings, transmission gears
Ceramic Bearings: Front wheel, transmission bearings
Engine:
Minarelli Motor
70cc Polini Evo Single Ring Race kit Liquid Cooled
Polini Crank
Polini Evo Exhaust (ceramic coated black)
Drowsports Autolube Block off plate
Stage6 PWK24 Carb
Stage6 V-Force Reed Cage
Stage6 Carbon Reed Petals
Stage6 Subframe
Stage6 Wedge Manifold
Custom Radiator
Samco Hoses
Electrical:
Drowsports Milspec Wire Harness
Drowsports R6 Tail Lamp Kit
Polini Race Ignition
Rigid Industries 6" SR Headlamp
Koso Gauge (gas/temp/speed)
Electric Water Pump
Cosmetics:
Drowsports Rigid Headlamp Bracket
Drowsports Electric Water Pump Bracket
Drowsports Shock Mount
Drowsports Carbon Gas tank cover
Drowsports Pegs
Drowsports Titanium Wheel spacers
Drowsports Carbon Glove Box
HIgrade Gas Cap Cover (black)
CRG Hindsight LS Mirror
Killer Scooter Frame Caps (Black)
Killer Scooter Handle Bar Stem
BTX Drag Bars
Mr. Shorty Chin Bone
Gojin Bolt Dress up Kit (Black)
PasswordJDM 2T Rear Frame
Recaro Seat Cover w/ Blue stitching & Memory Foam
Composimo License Plate Bracket
Brakes/Suspension/Wheels:
Drowsports Shock Bushings
Stage 6 left side controls
ASV Shorty Brake lever (Black)
RRGS Floating Rotor (Gold)
RRGS 4pot PH80 Caliper (black)
RRGS PH80 Caliper Bracket
RRGS Lowdown Forks (black)
RRGS 12mm Axle
RRGS CNC 90* Valve Stems (Black)
Frandol Brake Master
Composimo lowering springs
Goodrich Brake Lines
Goodrich Banjo Bolts
Goodrich Brake Line Fittings
Fox Vanilla Rear Shock
Asking $7,000 OBO. If you DON'T like my price or anything that have to do with the bike, please leave your negative comments out of my thread. If you have any questions pm or Email: sam@importlife.com
Powdercoated Black:
Engine:
Minarelli Motor
Polini Crank
Stage6 PWK24 Carb
Stage6 Subframe
Custom Radiator
Samco Hoses
Electrical:
Electric Water Pump
Cosmetics:
Drowsports Pegs
BTX Drag Bars
RRGS 12mm Axle
crx12
Welding / Fabrication
27
Mar 6, 2008 07:48 PM
MaxBoost
37
Mar 11, 2004 07:15 AM
