Transmission & Drivetrain Gearboxes, Differentials, Clutches
D series swap in 2000 Civic Si
Old Oct 13, 2013 | 10:39 AM
domestic_rice's Avatar
Default Do D series axles fit in a 2000 Civic Si????
The d series swap is in. My question is what kind of axles am I going to have to use? I have none right now. My logic is I need D series axles to go into the trans and such. But I remember Si hubs being larger. Or maybe that was just the wheel bearing. I can't remember and I don't want to go buy some axles that wont fit. So if anyone can give me a straight forward answer it will be greatly appreciated.
Thanks.
Old Oct 13, 2013 | 02:24 PM
Default Re: D series swap in 2000 Civic Si
Wow, I thought this would be an easy one. 80 views and no one knows?
Old Oct 16, 2013 | 06:50 PM
This must either be an incredibly easy question or people must just not know.
Turns out that they all seem pretty much the same. I got a set of shitty d series axles for free to test fit and they seem to work. They were rusty so they didn't go in all that easy but I think after a few minutes on pb blaster and a wire wheel they should be fine.
Old Oct 16, 2013 | 07:16 PM
slowDB7's Avatar
axles for any 92-00 d series civic will work just fine
didnt even see this thread before or i would have said something sooner
Old Oct 17, 2013 | 02:34 AM
Freemananana's Avatar
Yup. The standard models came with a D-series motor. Just get the axles from that. They should fall into place.
Old Oct 17, 2013 | 05:53 PM
Yep. I have three cars I'm doing swaps in and all different models and the only difference I'm seeing in the Si is the actual hub is bigger. Which means the wheel bearing itself is larger. But the diameter of the hole for the axle and number of splines seems to be pretty standard.
Thanks all!
Old Oct 18, 2013 | 05:00 AM
kyden's Avatar
ex and si have the same hubs anyway.
Old Oct 18, 2013 | 07:05 PM
Cool. That helps out for the other car that I'm converting from auto to manual.
Thanks!
gnxpro24
Dec 17, 2010 10:26 AM
253kingpen
Northwest (Sales)
Nov 5, 2008 08:24 PM
turboDeznutz
Nov 8, 2007 04:05 PM
litterbox
Mid-Atlantic (Sales)
Jul 9, 2005 10:00 AM
efjuice
Nov 3, 2004 12:47 PM
