94 accord corner blinkers stopped working plzzz help!!!
i tried wiring my bumper lights to my corner lights (blinkers) on my 94 accord and now the corner blinkers dont work but every other light on the car does and checked all fuses but they are fine wat could be the issue???
A 94/95 Accord bumper lights (turn signals I'm guessing?) and corner lights (also turn signals) both blink already. You have two bulbs in the corner light. One that blinks and one that doesn't. Were you trying to have your turn signals come on with the parking lights?
I'd look to see if you blew the hazard switch. Or what do you mean the corner blinkers don't work. What did you wire where?
I tried to wire them to the ones that stay on and blink not the ones that just stay on...as soon as I wired them it worked for that one second then turned off and now they don't turn on at all only the ones that stay on and don't blink work
Can you take a picture of what you spliced into. Also did you use the correct socket to do the constant bumper light mod (since that is what I am guessing you were trying to do) so you can use a dual filament bulb or did you just run the wire of the corner light into the positive wire of the original turn signal socket with the single filament.
If you are trying to do the constant bumper light mod you need to use the 6th gen civic turn civic socket and wire the blinker pos to the green wire and the corner socket to the red wire. Also make sure you use the non blinking socket to splice into since you have a 94/5 accord.
All I did was run the wire from the bumper lights to the wires of the corner blinkers that's all I did..right now my main concern is to get my corner blinkers working again and Idk how..all fuses all fine not one blew
And you need to be FAR more specific. What wire did you run and where did you connect it?
Have you checked to see if the bulbs have been blown?
my bumper lights still work as normal as well as all other lights except the corner blinkers is that normal even if the hazzard switch is busted?...and i cut the bulbs from the bumper light and connected those green and black wires sticking out of it the the green and black wires on my corner blinkers thats pretty much all i did then it stopped working.
Bumper lights have one bulb, two wires.
Corner lights have two bulbs, four wires.
You're saying to cut both wires from your bumper lights and cut the wires on the flashing corner light and connected them? What are you trying to accomplish with this? If I'm not mistaken, the flashing corner light is only on with the turn signal and alternates with the bumper light. The solid (parking) light is on whenever your parking or headlights are on.
You are still being too vague.
What were you trying to accomplish? Have your bumper lights be on all the time and flash?
yes thats exactly what i did. i wanted my bumper lights on all the time.. the corner blinkers stay on all the time as well as blink so thats where i connected the bumper lights to
the flashing corner lights are on all the time with my headlights and everything else so both corner lights stay i its just that one blinks and the other one does not i connected the bumpers to the ones that blink
Sounds like you were trying to rush it and halfa$$ed, Just unhook what you did and see if that fixes your problem. Then if you decide that you still want to do the bumper light mod do it right.
How about when you press the hazard switch? Does anything happen? Front. rear or inside?
everything is working fine and as normal. all other lights turn on and work as they should the only ones that dont work are the corner lights that blink. the first set of corner lights that stay on work fine but the second set which stay on as well as blink for turn signals dont turn on at all
HondaTech101
Dec 20, 2006 05:12 PM
tinhquaygot4ever
Dec 20, 2001 06:19 AM
