d16a6 build vs ZC
I own a 1988 Crx Si. I bought off of somebody who bought it as a project car. He was told that there was a new engine in it with 60k miles. it is a d16a6. The car had been sitting for 2 years when I bought it, which I payed $750 for it. The problem is that it overheats and it burns oil. but again, I payed $750 for it so I can't be mad that it has problems.
My question is should I fix and build the d16a6 or should I put a jdm DOHC ZC in it? Or should I put something else in it?
I want to put a motor in it that'll drop right in with no problem.
I've thought about the B series swap but that requires me to do more stuff to my car then what I want to do right now
Thanks for reading and tell me what you think
But, my honest suggestion, would be a B-series swap. The mounts and shift linkage are really the only non-stock components that are needed. But it is quite a bit more time consuming and 'harder' to do.
The Z6 will net you something like 115 whp and the B16A will get you closer to 140 whp. The DOHC VTEC motors brought a lot of efficiency into the Honda world in terms of power per liter. But the DOHC was never meant to be in the EF chassis and brings a lot of issues with it. Mostly fitment.
If money and time are tight, Z6. In a more perfect world, I'd say B18C.
I wouldn't go for the DOHC ZC, the parts are hard to find. If you want a different motor, and it to be a direct drop it, the D16Z6 is for you. If your transmission is good, just get a complete D16Z6 longblock with head.
I was going to say the same thing. I miss my old DOHC ZC very much. I'd add to what "jlicrx" said by saying it is not so much that it's harder to find parts for this particular engine but the key is knowing what is equivalent or interchangeable. If you know that, you realize (just as "jlicrx" stated):
It's really easy. Literally 2 wires.
Just something to keep in mind.
Going OBD1 shouldn't be pricy. When you get your block, try and get it with a distributor and the ECU. Most motors that come with the stock exhaust will have the stock O2 sensor still in it. So really, if you are just buying a motor, you will have to get the conversion harness for the Z6 but not the ZC. Either way, you still have to buy a distributor and ECU. I am not too sure on the actual price difference between the motors though.
Creepshow S60
Oct 13, 2002 05:06 PM
