valve spring recommendation
Old Oct 12, 2013 | 07:26 PM
PabloM's Avatar
Default valve spring recommendation
sup! need help with my b20, its stock except for the edelbrock manifold and 4-2-1 header, stock tb stock injectors everything else is stock and im wanting to rev up to 8200~ with it, the question is, do i need dual valve spring or single? how much pressure?
thank u!
Old Oct 12, 2013 | 09:14 PM
Rocket's Avatar
Default Re: valve spring recommendation
Stock LS/B20 springs are stupid light (light enough to be installed by hand) and need to be replaced with mildly stiffer units.
But I'd stay away from heavy dual springs, because high rocker ratio (1.75) puts a lot of pressure on the lobe.
Old Oct 12, 2013 | 10:35 PM
raverx3m's Avatar
u know that b20 stops making power at around 6000 rpm with everything stock why do you want to rev that high? you gain nothing by doing that.
Old Oct 12, 2013 | 10:36 PM
raverx3m's Avatar
even with boltons on my jdm b20 I can feel power fall on its face right around 6500 rpm I shift just before 7000
Old Oct 12, 2013 | 10:53 PM
UncleD's Avatar
No point in over stressing the motor for no benefit.
Old Oct 12, 2013 | 11:14 PM
raverx3m's Avatar
u need a gsr motor buddy
Old Oct 13, 2013 | 01:09 AM
PabloM's Avatar
how could i rise the power to 7500 or more? stage2 cams? hi-comp pistons?
the ecu is still untuned :S
thank you all !
Old Oct 13, 2013 | 06:57 AM
98vtec's Avatar
moderator emeritus
please take the time to do some research before you continue to make threads that show its obvious you have done none.
the FAQ is FULL of information.
hellaflushdb2
Jun 20, 2011 06:56 PM
emotionisdead
Nov 13, 2004 06:56 PM
REVOUTHIGH
Jun 24, 2004 04:54 AM
B20Coupe
Oct 13, 2002 07:45 PM
B20-T
Jun 24, 2002 11:00 AM
