b18 and b16 injector interchangeability question
Old Oct 12, 2013 | 06:32 PM
9honda5civic's Avatar
Default b18 and b16 injector interchangeability question
will obd1 b18 ls injectors out of a teggi work on my obd1 b16a?
Old Oct 12, 2013 | 06:46 PM
CO671's Avatar
Default Re: b18 and b16 injector interchangeability question
As long as they're OBD1
From my research, they also have the same flow rate
-I would also like to mention that the same question has been asked multiple times. So if you're really in a rush to find an answer, use Google. This trick specifically for finding quick answers:
(site:honda-tech.com ______)
Originally Posted by Ludeist
Honda/Acura Fuel Injector Stock Flow Rates
(source: TexasRacingScene, Genius)
Generally OBD1+ are Saturated, and non-OBD are peak and hold. There are a few exceptions however (as usual):
92-00 D16z6/y8, B16, B18b, B18c1/5, B20b/z - ~245cc, saturated
88-91 D16a1, B16, B18a - ~245cc, Peak and Hold
92-95 H22a, H23 - ~330cc, Peak and best on market for stock!! only in JDM engine ran with p13 ecu!
96-00 H22a, H23 - ~290cc, Saturated
A more detailed listings:
Honda/Acura Stock Fuel Injector Flow Rates
Engine Code Year Stock Flow Rate (cc/min)
G25A4 1995-1996 235
J30A1 1997 240
C32A6 1996-1997 240
B18C1 1996-1997 240
B18C1 1994-1995 240
B18B1 1994-1995 240
B18A1 1992-1993 240
B17A1 1992-1993 235
C32A1 1997 275
C30A1 1995-1998 325
C27A4 1995-1997 235
J30A1 1997 240
F22B2 1994-1997 235
F22B1 1994-1997 235
F22A6 1990-1993 235
F22A1 & F22A4 1990-1993 235
A20A3 1987-1989 235
BT 1986 235
ES3 1985 180
D16Y7 1996-1997 240
D16Y8 1996-1997 240
D16Z6 1992-1995 240
D15B7 1992-1995 235
D15B8 1992-1995 180
D15Z1 1992-1995 235
D16A6 1988-1991 235
D15B6 1988-1989 180
D15B6 1990-1991 235
D15A3 1987 180
EW4 1986 180
EW3 1985 180
B20B4 1997 240
D16Y8 1996-1997 240
B16A3 1996-1997 240
D16Y7 1996-1997 180
B16A3 1994-1995 235
D15B7 1993-1995 235
D16Z6 1993-1995 235
F22B6 1995-1997 235
H22A4 1997-2001 290
H22A1 1993-1996 325
F22A1 1992-1996 235
H23A1 1992-1996 235
B21A1 1990-1991 235
B20A5 1988-1991 235
BT 1985-1986 235
Old Oct 12, 2013 | 06:56 PM
ok thanks boss
Old Oct 12, 2013 | 06:57 PM
B_Swapped93's Avatar
google will find you the answer faster then on here.
sixfourkiller
Feb 19, 2012 09:04 AM
Syndacate
UK and Europe Regional
Aug 15, 2009 09:46 PM
2mchbst
May 17, 2009 03:01 PM
blackcrx16
Apr 15, 2007 03:42 PM
Jo Civic
Dec 13, 2006 10:12 AM
