95 civic front end noise
Old Oct 12, 2013 | 06:29 AM
tabrubaker323's Avatar
Default 95 civic front end noise
I have a 95 ex coupe. When driving it makes a front end hum what sounds like every time the tire makes a turn. It gets louder when i make a right hand turn. My initial thought was wheel bearing on the drivers side. While i was in there i noticed my outter tie tod boots were shot so i put both new ties rods on too. It makes the same sound with the clutch in or out. what else could cause this? thanks guys!
Old Oct 12, 2013 | 07:42 AM
fragmare's Avatar
Check that the backing plate behind the rotor is not rubbing. Also verify the CV drive axle dust boots are intact and not ripped or torn.
Old Oct 12, 2013 | 08:35 AM
Default Re: 95 civic front end noise
the axles look good and do not have tears and not a whole lot of play. and the backing plate is not rubbing
Old Oct 12, 2013 | 12:46 PM
janz3n's Avatar
i dont get it, you think its the wheel bearing, it sounds like a wheel bearing, it acts like a wheel bearing but you dont think its a wheel bearing because it still makes the same noise after replacing tie rods?
Old Oct 12, 2013 | 03:30 PM
CO671's Avatar
Are there any suspension, brake or wheel mods?
Were any parts replaced with aftermarket or OEM parts?
Have you done the 3-9 and 6-12 wheel shake test?
worder
11
Sep 23, 2011 05:25 AM
Brewer
Suspension & Brakes
18
Aug 20, 2006 09:19 AM
1INTEGRA
May 5, 2005 10:13 AM
Blastek
Oct 18, 2004 08:34 AM
Monkey Fing a Coconut
Oct 24, 2003 10:45 PM
