is 89mm crank (b20/ls) more sensitive to lean mixture and detonation?
Old Oct 11, 2013 | 08:52 PM
raverx3m's Avatar
Default is 89mm crank (b20/ls) more sensitive to lean mixture and detonation?
I know my gsr was reaching almost to 17 afr under acceleration on my first runs when I was initially adjusting basemaps.
but I never heard knock or any other choking I could feel the sound change when it ran lean but it didn't stumble
this b20 is acting strange.
any slight lean condition makes it fall on its face around 2500-3000 rpm and then it starts accelerating normally
the afr shows around 15.5-16
but datalog shows it go up to 16 and then drop and then spike back up and drop like square wave.
all other sensors show normal
is that because of 89mm crank more sensitive to lean condition or something other?
I checked vacuum leaks and all other things
all seems normal and it can drive all day and suddenly just throw that **** at me and then disappear again.
Old Oct 11, 2013 | 09:51 PM
yungmulacrx's Avatar
Default Re: is 89mm crank (b20/ls) more sensitive to lean mixture and detonation?
Are you running neptune?
Old Oct 11, 2013 | 11:06 PM
raverx3m's Avatar
yep why?
Old Oct 12, 2013 | 06:06 AM
I have some questions\observations in regards to neptune.. Is this problem when a laptop is hooked up or just random with or without laptop connected? Ill be starting another thread here in a day or two..
Old Oct 12, 2013 | 08:38 PM
raverx3m's Avatar
Usually i have my laptop hooked up but today i didnt and it happened randomly again and just once out of the blue again. I have a feeling its same issue that i had before but this engine is more sensitive to changes in afr and when it shifts towards lean condition i get these hiccups
Old Oct 13, 2013 | 07:00 AM
ennah's Avatar
Wideband could be reading improperly, timing could be an issue. Cruising afr I never go past 15.5.
Old Oct 13, 2013 | 07:29 AM
raverx3m's Avatar
its all been checked before over and over wideband timing sensors dizzy wiring ecu soldering etc
Old Oct 13, 2013 | 07:38 AM
How much timing are you running when these hiccups occur and im assuming its low load.. What issues, did you have before? Ive heard that not enough timing in low load can cause hesitation/hiccups but i am not positive.. Have you pulled a plug and seen any signs of detenation? I was hoping someone else would chime in and give some tech info on the question you asked.. Anyone want to share some tech/advice on the relationship of stroke, rod/stroke ratio, long rods, and short rods in regards to timing? Short rods=less time at tdc and long rods=more time at tdc
Old Oct 14, 2013 | 07:11 AM
AaronEJ's Avatar
if you like send me your calibration and a log file
and im sure i can help you out.
Old Oct 14, 2013 | 08:25 AM
raverx3m's Avatar
yea im gonna upload it
so to the original question.
is 89 and higher rod/stroke ratio more sensitive to detonation?
Old Oct 14, 2013 | 09:31 AM
AaronEJ's Avatar
its not more senstive
but higher rod stroke ratio allows less ignition timing advance.
Old Oct 15, 2013 | 08:49 AM
spAdam's Avatar
Loved
Community Favorite
Because...
Old Oct 15, 2013 | 10:50 AM
I believe its because the piston is at tdc for a less amount of time..
Old Oct 15, 2013 | 06:41 PM
VegasInvasion's Avatar
I'm Huge In Japan
Backwards.
When the piston sees less time at TDC it is less likely to detonate there.
The ATDC slope is faster, so combustion can happen faster, allowing more advance.
If this is a random occurrence you may have an incorrect IAT or ECT scale or an ignition/timing issue, but it may just be a misfire, not detonation.
Verify again that your base ignition is correct and your timing belt is properly tensioned, then make sure your dist cap isn't full of carbon. While it's off, check the coil resistance.
Lean cylinders are also common in B series, so next time it happens kill the engine and pull the plugs, look for one with discoloration.
Old Oct 15, 2013 | 07:08 PM
spAdam's Avatar
Loved
Community Favorite
Originally Posted by VegasInvasion
Backwards.
Correct. I made my previous comment... kind of in passing because I was at the end of lunch... to try and spur a little more tech in the discussion. A little "why" usually goes a long way toward understanding
Old Oct 15, 2013 | 09:12 PM
raverx3m's Avatar
but the piston speed is higher with bigger stroke.
VI according to what you said the b16 would have the easiest detonation and b20 would have a lot less...
just don't feel right for some reason
if looking at tdc dwell time alone maybe
but taking into account the piston speed and the angle with bigger stroke
Old Oct 16, 2013 | 08:32 AM
AaronEJ's Avatar
when you look just at the R/S ratio a b16 is will allow more advanced timing then a B20
but the ideal ignition timing has a lot variables
like : Fuel,rod stroke ratio, stroke, bore,Compression, IAT, ECT,EGT, Exhaust back pressure and so on.
so its not that easy as most of etuners think.
sure its not that hard to find a ignition timing that works,
but to find the right shape of the timing curve requires long expierence in tuning.
Old Oct 16, 2013 | 09:53 PM
raverx3m's Avatar
yea after 3 years of reading and attempting to street tune and spying on rich lol I still cant understand ignition adjustments.
I got the fueling pretty good but not ignition.
on this one I had to increase the iat compensation when it gets past certain IAT temp because it was getting a lot leaner with hotter IAT but stock is negative compensation.
am I doing it right?
wrestler72
Sep 5, 2007 08:24 AM
jdm92teg
Apr 13, 2005 01:20 PM
torr
Feb 25, 2003 12:00 PM
LsPower
Jan 17, 2003 11:01 AM
