after putting silicone lube on OEM jack, now its hard to turn ?
Old Oct 11, 2013 | 08:40 PM
crxaddikt's Avatar
Default after putting silicone lube on OEM jack, now its hard to turn ?
my stock OEM jack worked fine, but i thought it would work even better if i lubed it up since i've never done that before, so i read a couple different posts doing a google search and a couple people said to use silicone lubricant, so i used a spray silicone lube i had on the threads and all the parts of the jack, but next time i used it, it seemed almost like it was stuck and i had to really force it to make it turn,
so my question is, what can i do to get the jack to work properly again ???,
like some type of lube to put on it ?, or should i use some type of degreaser or something to get the coating of the silicone lube off of it first?,
any input would be cool, thanks
Old Oct 12, 2013 | 04:49 AM
Lizardslap's Avatar
Default Re: after putting silicone lube on OEM jack, now its hard to turn ?
just blob a little bit of grease on the threads and rotate it up and down get it till it moves free probably just a bit of corrosion on the threads where it needs to rotate
Old Oct 12, 2013 | 05:26 AM
Former User's Avatar
Silicone lubricant generally should not be used to lubricate metal parts. It is used on rubber parts.
Originally Posted by Lizardslap
just blob...grease on the threads and rotate it up and down...till it moves free
This^
Old Oct 12, 2013 | 07:09 AM
TripleLude's Avatar
The only purpose of silicone spray on metal is to protect it from rusting. Use some wheel bearing grease or something like that if you want to lube it.
Old Oct 12, 2013 | 03:16 PM
tubejim101's Avatar
The silicone spray was just a coincidence. Should not hurt anything. I would put some white lithium grease on the jack.
Old Oct 12, 2013 | 03:21 PM
No coincidence. The silicone lubricant actually caused the problem because it removed the grease and doesn't lubricate metal-metal contacts.
raverx3m
Jan 3, 2016 05:50 PM
crxaddikt
Oct 12, 2013 09:10 AM
