Private Label MFG SHIFT KNOB & FULLY ADJUSTABLE SHIFTER (B/D)
*** PM ME FOR FORUM PRICING ***
__________________________________________________ __________________________________________________ ______
Private Label MFG SHIFT **** & FULLY ADJUSTABLE SHIFTER (B/D)
COMBO 199.99 DOLLARS MSRP +shipping
PM ME FOR HONDA-TECH PRICING
BASIC INFO:
The PLM ball type shift **** is one of the popular shift ***** on the market. Made of the same material of the OEM Honda aluminum, it combines both improved feel, shortened height and response.
M10x1.5 - HONDA ONLY
WEIGHS 5ozs
BASIC INFO:
The Private Label Mfg Fully Adjustable shifter is constructed with high quality alloy steel for maximum durability and reliability to ensure the shifter will last. The added weight of the shifter results in smoother and more positive shifting with the ergonomic design that just falls into your hands, to the very first ultra-smooth shift. The shifter was designed to have an adjustable ratio as the stock shifter to an more aggressive feel. The shifter is fully height adjustable to accommodate each drivers desired position, as every driver is different. The shifter certainly does not look stock, but the shift feel and throw can be adjusted like the stock shifter. Each short shifter features a non-binding sealed bearing and a low friction coating that ensures smooth and precise shifting, even under the harshest driving conditions.
Features
• 2-part design for easier installation
• Fits any Honda/Acura thread-pitch ****
• Adjustable handle compensates for small-diameter racing steering wheels
• Revised shift linkage bushings for even smoother shifting
• Standard Honda/Acura 10x1.5mm thread pitch and shift **** applications
• Made from high grade stainless steel & billet aluminum
• Machine spun stainless finish
• Shift **** not included
• All necessary allen keys for adjusting included
