97 civic sedan measurement
i have wreaked 97 civic sedan. can someone give me this measurement.
Under the hood looking at the strut threads sticking up from the wheel well. Measure from the left strut threads to the right strut threads, center to center.
let me know if you had to lay the tape measure over top the air intake or not. that way i can compare it to mine the same way. the reason is i was hit and think it may have bent the entire shock tower inward and need to know what to bend it out to.
thanks
thanks
Ah I saw this thread but it was 2am and I ended up falling asleep before going outside to measure.
I'm at work so I can't do it, but I posted in the 96-00 sedan thread about your request
Hopefully somebody will make the time to check
https://honda-tech.com/forums/group-threads-123/%2A%2A-offical-96-00-civic-4dr-thread-%2A%2A-part-2-a-2238014/
wait a minute'
what if getting hit low in the tire / door hinges caused the shock tower to move outward!!!!!. is this possible?
can somebody else measure? i had no throttle cable in the way as noted above.
measure from strut thread left to right center to center with stock air cleaner removed (top half).
thanks
thanks
97civic89
May 15, 2013 01:53 PM
