How is the "Door panel stiffener" held on?
Old Oct 10, 2013 | 07:52 PM
LoveDeezNutz's Avatar
Default How is the "Door panel stiffener" held on?
My door started making noise, thought the window fell off the arms, got home took the panel off, looked at the arms, windows still held on firmly.
I am assuming the name is "Door panel stiffener" I thought it was the door reinforcement bar, but anyway. How the hell does this stay on?
I am referring to piece of metal that goes in between the outer door frame and inner door frame, where the window sits.
The part attached going towards the rear is still attached, but the part that goes towards the front isn't which is causing the noise. It is in a horrible place, I got home late and didnt want to remove my speaker, but seriously it seems like PIA to look in there.
Is it held on by a bolt or screw? does it pop into something? I noticed there was some black foam like gunk that was holding it against the outer door panel, but that is gone.
I doubt it was welded on, unless it was at the ends.
Can someone give me some sort of idea of how its held on so I know what to expect to have to do over the weekend, I could cut it out, but I am assuming its purpose is to lessen the damage caused by shopping carts, car doors, and people kicking it so I would like to have it actually functioning.
Thank you
Old Oct 11, 2013 | 02:53 AM
Freemananana's Avatar
Default Re: How is the "Door panel stiffener" held on?
I want to say bolts or a rivet. I would just drill a hole (don't hit the glass) and put a bolt in it anyways. I know what you are talking about, but I don't feel like opening up my door to look. Maybe check your other door and see if there is anything holding it on. That would be a sure fire way to figure it out.
Old Oct 11, 2013 | 04:41 PM
I found out there is a hole. I do not know if it was a screw (if so the head broke off as the hole is filled) or rivet, but it doesnt matter because i cannot deskin and reskin the door to fix it correctly.
Does anyone know if hondabond will work? If so is there a metal to metal version or is it just hondabond? I was considering the 3m foam, but I do not know if this would hold it, plus its like 50 vs hondabonda which was 18.
Thoughts? again metal to metal adhesive.
Old Oct 12, 2013 | 04:10 AM
Can you get sand paper in between the surfaces? That helps with adhesion. Also, make sure it's clean. But I suggest JB-weld. It's less than $10. It's a 3 part system and it is made to be as strong as a weld for metal to metal. I've used it on several things. One of the nipples on my throttle body broke off, I drilled it out and JB-welded a new fitting in.
Old Oct 13, 2013 | 05:27 PM
Spug's Avatar
Just drill a hole in the inner door skin, clamp the two together, and weld them together.
Old Oct 13, 2013 | 06:10 PM
Wish it was just that easy haha. I don't have a welder myself.
ek400
Feb 10, 2011 02:19 PM
neo_
Apr 7, 2007 11:48 PM
5G_Vtec
Mar 9, 2007 06:58 AM
Diao
Jan 10, 2007 04:29 PM
hmongboyLS
Jul 17, 2003 11:50 PM
