Clutch pressure problem!
I have a 1999 gsr integra. While driving home from work i noticed the clutch pedal had lost some pressure. It gave me problems getting into gear but i ended up getting it home. The next day i took a look at it at noticed some leaking from the CMC. I replaced it and tried bleeding the lines, got some pressure but not back to what it was. I then replaced the slave thinking that had to be the problem. But this gave me no luck. Traced the lines and did not find anything leaking. I have bled half of one of the big bottles of brake fluid. I even adjusted the clutch pedal to give me max range to pump to CMC though it still almost feels short compared my eg. If I put the car in reverse or first gear before i crank it I can idle and drive it but cant switch gears and the clutch engagement point is "lower". I'm starting to think its the pressure plate but supposedly its a brand new exedy stage 2. Any ideas?
No, on the clutch disc itself, something like this...
http://www.google.ca/imgres?start=11...3&tx=174&ty=84 94
RTW DC2R
Jun 23, 2006 07:42 AM
