FS PA : K20z3 part out
Old Oct 10, 2013 | 03:16 PM
Nasa_Crz's Avatar
Default FS PA : K20z3 part out
will be adding parts on the daily. check back or message me if you dont see what you are looking for. parts are obo and do not include shipping. only shipping to lower 49 states
*mods* if needed i can get pictures with h-t tags.
this is my sale thread on k20a.org - http://www.k20a.org/forum/showthread.php?t=132554
also have one on nwp4life - http://forums.nwp4life.com/zerothread?id=45409
if anyone needs pictures look in these above threads or just ask for a picture and i can post it up!!
k20z3 oem piston and rod set. one bent rod - $45
k20z3 oil pump - $70
k20z3 side engine mount - $20
k20z3 crank sensor - $20
k20z3 chain sprocket drive - $20
k20z3 crank pulser plate - $7
k20z3 oil pump chain and guides - $10
k20z3 timing chain cover - $30
k20z3 vtc oil control solenoid - $20
k20z3 vtec solenoid - $45
k20z3 oil pan bolts - $10
k20z3 oem injectors - $20
k20z3 oem flywheel bolts - $15
k20z3 tb - $35
k20z3 belt tensioner - $25
Cut and ported rbc - $400
Rdx injectors - $150
z3 crank - $150
z3 head no cams, valve cover and vtec solenoid - $450
z3 bare block with girdle, needs one oil squirter replaced - $200
z3 thermostat, housing and line - $30
z3 timing chain guides - $35
z3 crank pulley - $25
z3 engine harness - $75
z3 flywheel - $35
k24 crank pulley - $20
k24 timing cover - SOLD
k24 oil pump tensioner - SOLD
k24 oil pump chain and guide - $10
k24 thermostat housing and line - $25
k24 water outlet assembly - $20
k20 and k24 fuel rails - $10
k20 and k24 oem head studs, never retorqued - $15
k24 vtc oil sensor - $20
k24 crank sensor - $20
k24 knock sensor - $15
k24a1 piston and rods, only have 3 - $30
k24a1 oil pump - $55
k24a1 vtec solenoid - $20
k24a1 water pump and housing - $40
crv dbw throttle body - $35
b series p.s. pump - $30
08 si oem header - $35
k series valve cover nuts - $10
oem oil cap - $3
K series coil pack cover - $10
k series coil packs - $50
ctr wing no base - $100
oem 99-00 si front lip with hardware - $250
ep3 seats with custom ek rails - $250
Old Oct 14, 2013 | 03:09 PM
Nasa_Crz's Avatar
Default Re: FS PA : K20z3 part out
*mods* can add pictures with a ht card if needed
have a thread on k20a - http://www.k20a.org/forum/showthread.php?t=132554
also on nwp4life - http://forums.nwp4life.com/zerothread?id=45409
k20z3 tb - $35
z3 crank - $150
z3 flywheel - $35
oem oil cap - $3
Old Oct 14, 2013 | 03:27 PM
crazi92hb's Avatar
Wow look at that rust... how much for the head
Old Oct 15, 2013 | 07:10 PM
Nasa_Crz's Avatar
not exactly sure yet. im in the process of moving to a different garage. once i get settled in i want to take the head off and see exactly whats still good and whats bad. i dont want to sell anyone something thats messed up.
Old Jan 1, 2014 | 02:15 PM
Nasa_Crz's Avatar
bump
NeonPinHead
Apr 30, 2015 07:30 PM
Spoon84
Nov 11, 2013 07:59 PM
