1997 Accord cranks, doesn't start
Old Oct 10, 2013 | 12:10 PM
1965fairlane's Avatar
Default 1997 Accord cranks, doesn't start
1997 Accord Sedan EX automatic
105,000 miles and seems to be in great shape.
The girlfriend was 20 miles into her drive to work on the interstate, when the car loses power, sputters, dies, and will not start back up. The car will crank (engine turns over) when the ignition is turned, but never starts. There is over a quarter tank of gas in the car. GF swears it is the fuel pump.
I checked for spark with an inline plug tester I purchased. All four cylinders created spark (although it was dim). I can hear the fuel pump kick on when the ignition is turned to on. The CEL is on and the code is P1382 -Cylinder Position Sensor -no signal. I can clear the CEL, and it immediately returns when you try to start the car.
I have read the 20 or so threads here about p1382, but they all have no spark as a symptom. I have spark (and appear to have fuel), so what else could it be?
Ideas are very welcome.
Old Oct 10, 2013 | 09:58 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1997 Accord cranks, doesn't start
...The CEL is on and the code is P1382 -Cylinder Position Sensor -no signal. I can clear the CEL, and it immediately returns when you try to start the car.
P1382 Cylinder Position (CYP) Sensor No Signal
If the PCM does not see a signal it cannot command correct spark timing.
Tech Auto Ignition
You may want to check that the harness is plugged in fully and not oil fouled or damaged.
CYP pickup(s) are about $125.
Call your local Honda dealership if the car really only has 105Kmiles. That part may still be covered under an emissions warranty.
KYRGYZ
Aug 17, 2017 09:14 AM
VeroNole08
Nov 13, 2013 06:55 PM
RKDGSR01
Jul 10, 2010 10:57 PM
loonysalmon
May 11, 2008 11:12 PM
