Civic shuts off at a stop help me
Old Oct 9, 2013 | 10:33 PM
rexking44's Avatar
Default Civic shuts off at a stop help me
I have a 97civic ex sedan now the problem im having is sometimes when im driving and i come to a stop my idle will drop to 0 and shut off then the battery lightturns on but it will start rite back up when i turn the key. It doesnt have a knock sensor but im not sure if thats causing the problem plz help me out appreciate it
Old Oct 10, 2013 | 03:27 AM
Former User's Avatar
Default Re: Civic shuts off at a stop help me
CEL codes?
Try cleaning the IACV and fix the KS code if there is one.
Old Oct 10, 2013 | 05:32 AM
Grape Ape Guy's Avatar
When is last time you changed your fuel filter? I cleaned IACV, replaced fuel regulator(was bad anyway as I found out), valve adjustment, dist cap and rotor, plugs and a host of other troubleshooting and it turned out to be a sludged fuel filter.
Old Oct 10, 2013 | 10:13 AM
Cody Pereira's Avatar
My 95 Del Sol did that very same thing to me just before the motor spun a bearing... Come to find out, when the motor sensed the low oil pressure (when i came to a stop) the motor would cut off as a precaution. You had said that your battery light comes on, but make sure that its the ONLY light that comes on!
Old Oct 10, 2013 | 10:30 AM
kyden's Avatar
negative. the motor does not shut itself off with low oil pressure. that is the motor seizing.
Old Oct 10, 2013 | 10:44 AM
Kyden, my motor did not sieze. I am still able to crank the motor over by hand.
bman2700
Aug 10, 2014 11:09 AM
EH6jade
Mar 23, 2013 01:44 PM
big b280
Nov 28, 2011 04:06 PM
donmeca2020
11
Jun 25, 2010 08:05 AM
Misha80
Aug 27, 2007 05:01 PM
