88 CRX - back firing and cooling problems
Old Oct 9, 2013 | 04:53 PM
djkutlee's Avatar
Default 88 CRX - back firing and cooling problems
Hey guys and girls ive recently purchased a 88 Crx, the previous owner said it has been sitting for a year , and it runns but it has some backfiring trouble , as far as maintenance goes what should I do?
P.S Also have cooling issue I bleed the radiator and it ran good for a while , but it started again what should I do?
Old Oct 9, 2013 | 04:58 PM
90_EX_Civic's Avatar
Default Re: New :P
how many miles on it?
did you ask when the last time it had been serviced?
last time water pump and timing belt got changed?
when the car is running and it starts to overheat, is the top hose hot?
check your spark plugs on the backfiring issue.
that's all i have for now.
Old Oct 9, 2013 | 05:22 PM
djkutlee's Avatar
Default Re: New :P
200,000 plus definitely
I asked and he said he had no clue
The Water pump and time belt have probably never been changed
I dont believe so
and I will
I pretty sure it needs a full tune up
Old Oct 9, 2013 | 05:57 PM
Default Re: New :P
I dont believe so
and I will
might be your thermostat is causing the overheating.
Old Oct 9, 2013 | 06:37 PM
djkutlee's Avatar
Default Re: New :P
Also Whenver It does overheat and IM idle at a stop light itll die what could that be?
Old Oct 10, 2013 | 03:01 AM
Freemananana's Avatar
Default Re: New :P
This seems like a long road of work ahead of you. The water pump probably needs to be replaced. You could get a new thermostat if your fans aren't turning on. Check the spark plugs for the backfire. It must be running rich for there to be combustion in the exhaust, that's what backfiring is to me. Probably replace the spark plug wires and plugs. A new distributor cap. Change the oil, change the antifreeze and replace the water pump. Change the timing belt. Possibly a new fuel filter and call it good.
Aside from regular maintance, you got to figure out the backfire and your overheat issue.
Old Oct 10, 2013 | 08:44 PM
djkutlee's Avatar
Default Re: New :P
Well i ran fuel cleaner in it today and it ran like a champ changed the spark plugs and tomorrow changing the oil/ oil filter filter and yes it is running rich because it only has headers, straight pipe, and catalytic converter
Old Oct 11, 2013 | 02:37 AM
Default Re: New :P
I know the exhaust prevents back pressure, but I didn't think any of that had to do with it running rich. I thought the ECU controlled the air to fuel ratio with the O2 sensors, which is usually on the header or just after.
crx6662
Mar 19, 2007 09:58 PM
snoop_bealybob
Mar 26, 2003 06:04 PM
wonny
Dec 7, 2002 05:45 AM
JDM DC2
Aug 29, 2002 11:39 PM
Fooman
Oct 25, 2001 02:47 PM
