Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic 02 EX - Best Bang for my buck for service $1000 limit
Old Oct 9, 2013 | 12:31 PM
kw151002's Avatar
Default Honda Civic 02 EX - Best Bang for my buck for service $1000 limit
I just bought a 2002 Honda Civic EX - around 100K miles
I have no history on it except for carfax - I have 1k budget so what should I get serviced to extend its life.
timing belt
power steering belt
AC compressor belt
various seals/gaskets
tensioner
water pump
water pump seals
what else should I have taken care of..
All the fluids and filters like transmission ,etc
Old Oct 9, 2013 | 04:21 PM
toyomatt84's Avatar
Sanji
Default Re: Honda Civic 02 EX - Best Bang for my buck for service $1000 limit
Definitely do a thorough check on the cooling system (including the heater core), as well as the transmission.
Old Oct 10, 2013 | 10:19 AM
husyk's Avatar
The car is due for timing belt service, that is around $700 for full service.
Old Oct 10, 2013 | 05:39 PM
Maugutus's Avatar
timing belt
power steering belt
AC compressor belt
tensioner
water pump
water pump seals
In order of bang for your buck.
First replace what is evidently broken/breaking first. Timing belt, water pump, idler, valve lash, oil change are a must. Then the crank and cam seals, the valve cover seals, various o-rings, replace the thermostat, replace ALL the coolant hoses. Clean the EGR valve and airways.
Get the car aligned, change the tires, check the Auto Tranny fluid, change the coolant (flush as well, see above timing belt service,) replace the brake fluid, replace the powersteering fluid, (old fluid speeds breakage on all parts internals,) check the rear drums, inspect the discs, brake pads, check the wheel bearings, check the axles, lubricate the pinions on the caliper, lubricate all other hinges.
Old Oct 21, 2013 | 09:44 AM
kw151002's Avatar
Thanks.
zachz41
Mar 12, 2011 02:29 PM
maflover2
Feb 27, 2008 07:40 PM
paulsie1123
Oct 9, 2005 07:11 PM
