Problem with D16Y7 cam into D16Z6 head
Old Oct 9, 2013 | 10:57 AM
johnson3548's Avatar
Default Problem with D16Y7 cam into D16Z6 head
Hello if this has been discussed all ready I'm sorry but to make a long story short my engine is a D16z6 I needed a new camshaft/w pulley so I went to the junk yard and could only find D16y7's so I bought it and tried it but now when the rocker arm is on the cam won't spin. Is it bc the current rocker arm is still the d16z6 and it needs to be from a D16y7 to match the cam??
ANY help will be greatly appreciated lol
Old Oct 9, 2013 | 12:50 PM
crazyhouse2011's Avatar
Default Re: Need help with a D16z6
Wrong head, kiddo. You need a z6 head, y7s wont werk.
Old Oct 9, 2013 | 12:52 PM
kyden's Avatar
why would you think a nonvtec cam would work on a vtec motor?
Old Oct 9, 2013 | 01:04 PM
carlos8's Avatar
I see few y8's engines here with y7 cams and complete rocker assembly.
I think isn't worth you need to block the vtec, buy rockers Assy. from y7 and
change your ECU tune (if it's chipped) or swap ECU plus no VTEC.
You be better with the correct cam for your head.
Old Oct 9, 2013 | 01:26 PM
Ok thanks for the help. I got the y7 cam bc apparently the z6 motor is not a easy find over here and I called honda and they said the cams are the same part numberso I figured they'd be the same. I've literally been to every junk yard and have seen at least 80 civics and not 1 is a z6 lol all y7's or b series
Old Oct 9, 2013 | 05:48 PM
carlos8's Avatar
Hey man I was looking for some items on ebay and check the z6 cams, there are 2 of them one for $75.00
Ebay item num. 200972387643
sorry I don't know how to copy the link.
Old Oct 10, 2013 | 12:11 AM
jbpnoman's Avatar
LOL whoever told you the Z6 and Y7 cams are the same part number is a ******* idiot.
Z6 - 14110-P28-A00
Y7 - 14111-P2E-A10
If you want to retain full functionality, you can use a Y8 or A6 cam in a Z6. If you use a Y7 cam, you'll have to do a lot more work, and you'll lose VTEC, period.
Meixellz
Feb 14, 2015 11:34 AM
Undergroundeg6
Feb 20, 2012 07:36 AM
b.serious
Nov 15, 2008 03:34 PM
b.serious
15
Nov 15, 2008 03:32 PM
89dohcEF
Oct 22, 2003 04:20 AM
