//'95 civic coupe//
Old Oct 9, 2013 | 06:16 AM
maxwellmercer's Avatar
Default //'95 civic coupe//
Testing waters on my weekend warrior.
I've owned the car for over two years now. It has been around town for about 10 years, I know all the ins and outs of the car.
I have a clean title, IN HAND.
I have receipts for nearly everything that I've bought, done or, had done to the car.
Chassis is a 95 ex coupe, ALL power options, everything works.
There is around 128k on the shell itself, the original cluster was swapped for an SiR which got stolen but I havent driven the car much since so the chassis mileage is pretty accurate.
**Everything mechanical on the car has around ~3000 miles on it.
Motor is from a 95 gsr, I have a copy of the title to prove it is legit.
Freshly rebuilt motor.
b18c1 bottom end, fresh hone, p30 pistons on gsr rods,
acl race main,rod,thrust bearings,
oem honda piston rings,
oem honda headgasket,
oem honda water pump,
oem honda oil pump
the head is from a b16a, fresh valve guides, seals, gaskets, everything is OEM.
golden eagle ls/v kit (because I found out my head was plugged for it after it was installed.)
the two are paired together with a gates racing timing belt.
ARP headstuds
Transmission is from a jdm b16a, like butter, but scratches 3rd sometimes.
Brand new Exedy stage one clutch.
ALWAYS used Honda MTF
ITR intake manifold with OMNI power 68mm throttle body (new map and tps sensors) onto a 3 inch intake.
oem honda intake manifold gasket
oem honda throttle body gasket
Hasport motor mounts
new distributor
Mishimoto triple core radiator with an FAL slim fan
street tuned by rcautoworks (chipped p06 on chrome, converted to vtec)
Engine bay was taken down and sprayed smoke grey. (tons of new OEM bolts)
ABS system was removed and replaced with a 40/40 prop valve.
new brake hardlines to all four corners, inlcuding the master cylinder lines.
Brakes/Suspension:
1 inch brake master cylinder with power booster
All new brake hard lines and fittings were installed in the process.
Russell stainless brake hoses on all four corners of the car.
All brakes are in working order, fresh ATE blue fluids
new pads and rotors on all four corners
Brand new ITR caliper upgrade in front with.
Autozone rotors with Hawk HP+ pads
Autozone rotors with ceramic pads in the rear
ARP extended studs all around
New wheel bearings in front, and hub assemblys in the rear when I did the studs
new lower ball joints, outer tie rods, and steering rack.
blox upper control arms (with competition series ball joints)
energy suspension bushing kit all around
function and form type2 coilovers
whiteline 22mm rear sway bar kit
Rays Engineering GramLights 57c 16x7 +43 with Toyo t1r 205/45 less than 3000 miles on setup
Interior/Exterior:
Interior is super clean, oem black.
Stock cluster with a stack clubman st200 tach integrated
(will come with stock si cluster unless i get what i want for the car)
recaro SPG seat, and stock passenger seat.
g force racing 5 point harness
fastline shifter
mugen slim shift ****
RCautoworks 4 point rollbar
Everything is there minus the rear seats (which i have an can be included)
AEM wideband
AEM water temp gauge
OEM optional console
personal black/yellow stitch wheel
(quick release pictured is not included, it was borrowed)
works bell hub
Stock SI lip
Super rare Denji headlights
J's racing honda primo banner
Original paint! Still shines great. Clayed/waxed twice a month.
CONS:
body is almost 20 years old
no ac/power steering/cruise
There is some rust on the driverside rear quarter panel
Dings here and there, the worst thing on the car is the hood, which isn't too bad.
***The radio and seat are staying with me.
***Also, all personal stickers will be removed minus the J's racing banner.
I have put countless hours into this build and don't need any insulting offers.
With that being said, I have NOTHING to hide on this car.
If you have ANY further questions at all, please feel free to contact me.
I am here to make a sale, not waste anyone's time!
I'm not looking for trades but, maybe an s14?
Outright price is $5000obo.
815.582.7931
Old Oct 11, 2013 | 08:35 AM
Default Re: //'95 civic coupe//
Pending sale on the shell for tomorrow. If thats the case the motor, wheels, etc will be up for grabs!
Old Oct 12, 2013 | 03:01 PM
Shell sold!
Old Oct 12, 2013 | 07:00 PM
civic_1's Avatar
Lol that was fast! Bump for you buddy! You sell the recaro too?
Old Oct 13, 2013 | 04:25 AM
kings**t's Avatar
What do u want for the swap?
Old Oct 13, 2013 | 07:04 AM
Looking to get 2200, with a small amount of wiggle room.
This will be a COMPLETE swap! Motor, trans, linkage, axles, ecu, wiring, mounts, hoses, header, etc.
Completely turn key!
dc2twincam
Jan 27, 2014 06:21 PM
maxwellmercer
Sep 5, 2013 11:36 AM
maxwellmercer
Aug 20, 2013 05:25 AM
Pai Mei
Jun 2, 2009 08:59 PM
