wurring noise on releasing clutch
Old Oct 8, 2013 | 05:51 PM
Dobird78's Avatar
Default wurring noise on releasing clutch
Ok only from a stop when I release the clutch I get a wurring noise. Not sure what it is but it doesn't happen all the time. Any input?
Old Oct 8, 2013 | 06:03 PM
NZXTInerTia's Avatar
What gear? Stopped at a stop sign? Age of clutch? Miles?
Old Oct 8, 2013 | 11:04 PM
holmesnmanny's Avatar
Default Re: wurring noise on releasing clutch
It's probably the input shaft bearing bad. It starts making that sound when the clutch pedal is out when it's bad. When you're moving you just can't hear it.
Old Oct 9, 2013 | 05:50 PM
Dobird78's Avatar
234,000 on whole tranny no work done as far as I know. Still pulls strong. Usually in 1st gear. Is this a whole clutch replacement or is the bearing an internal issue. I'm not too familiar with standard trannys as far as internal work
Old Oct 9, 2013 | 10:44 PM
You have to pull the tranny and it's inside the tranny. It might be best to pull the tranny yourself then call around to someone that will just replace the bearing and take the tranny to them.
Old Oct 10, 2013 | 06:25 PM
Dobird78's Avatar
I'll probably pull and replace the whole clutch assembly and bearings after talking to some folks and checking out videos it shouldn't be too bad to take care of
vlc92189
Jul 23, 2006 05:01 PM
JDM SLICK
Feb 15, 2005 11:17 PM
bambbrose
Dec 12, 2004 10:17 PM
Jason C SBB
18
Feb 22, 2004 11:37 PM
91HATCH
11
Jan 14, 2002 06:47 PM
