wheel weights in pdf format
Old Oct 7, 2013 | 10:28 PM
raverx3m's Avatar
Default wheel weights in pdf format
I saved the wheel weights from the interwebs before the page shut down and they changed the profile that wont let you change parameters
I saved them separately by:
wheel weight---weight
wheel size---size
wheel brand-- alpha
thought It would be good idea to host them on HT
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 8, 2013 | 02:12 PM
toyomatt84's Avatar
Sanji
Default Re: wheel weights in pdf format
If you're referring to wheelweights.net, I don't know what prompted you to think the site was getting shut down.
Old Oct 8, 2013 | 04:22 PM
raverx3m's Avatar
the original site was shut down that hosted these about 8-9 years ago. the new xl sheet don't let you sort by weight/size/ manufacturer
Old Oct 8, 2013 | 07:42 PM
toyomatt84's Avatar
Sanji
I'm having no problems sorting by column. I don't see what you're talking about.
Old Oct 8, 2013 | 07:56 PM
raverx3m's Avatar
I don't see any options in excel viewer to do any kind of sorting..
Old Oct 8, 2013 | 08:12 PM
toyomatt84's Avatar
Sanji
I run OpenOffice at home here, and can manipulate the columns as I see fit. Are you opening the file as "Read-Only"? Because that would prevent you from doing any modifications.
Old Oct 8, 2013 | 08:54 PM
raverx3m's Avatar
excel viewer don't have options open office doesn't work well on my system I tried it many times its slow as sht...
Old Oct 9, 2013 | 04:16 PM
toyomatt84's Avatar
Sanji
I tried opening the file at work today, and had no problems changing the sorting options... only once I saved the file locally. You cannot edit the sorting, whilst in "Read-Only" mode, which is why you probably can't do anything in Excel Viewer.
Old Oct 9, 2013 | 06:08 PM
raverx3m's Avatar
ok bro I don't know what your problem is why the f is it so important to you.
maybe your excel viewer has options mine doesn't
damnnnnnnnnnnn find something else to pick on
Old Oct 9, 2013 | 08:37 PM
toyomatt84's Avatar
Sanji
I'm trying to help you, and you're getting defensive? You're reading far too much into this. If you think I'm picking on you, you're clearly mistaken.
Old Oct 9, 2013 | 08:51 PM
raverx3m's Avatar
like I said theres nothing in my excel viewer it just shows it in one format that's it
you are talking about Microsoft excel
excel viewer and ms excel is not same thing
how is you helping me exactly?
Old Oct 10, 2013 | 06:50 PM
toyomatt84's Avatar
Sanji
Excel Viewer only opens files in "Read-Only" format; hence why you cannot alter the arrangement of the wheel order by weight/size/etc, at your discretion. In order to change the arrangement of anything on a spreadsheet, it needs to be opened in a non "Read-Only" format. You're complaining about them "changing the profile that won't let you change parameters", but they clearly haven't. I was trying to help you work around the new file format, so you could organize the file as you saw fit.
Old Oct 10, 2013 | 09:37 PM
raverx3m's Avatar
because I don't need to. I have it saved in pdf that has much better format with alternating colors. I don't have to modify anything...
Old Oct 11, 2013 | 07:01 PM
toyomatt84's Avatar
Sanji
Just so you know, they are still adding information to that spreadsheet. So, if you find yourself looking for a wheel that isn't on your lists, you'll still have to go back to their spreadsheet. I can alter the spreadsheet to look like the .pdf's, if you want to see more current data.
Von Tran
Honda Ruckus and Scooters
Mar 12, 2019 06:25 AM
konvikt
Jan 4, 2007 08:46 PM
H.crx-si
Feb 19, 2005 07:43 PM
