03 ex cluster swap into 96 ex (started)
Old Oct 7, 2013 | 08:15 PM
kaboomfox's Avatar
Icon2 03 ex cluster swap into 96 ex (started)
I am got mine almost done... I'll do a full write up but here is a teaser
My brake is really on fyi:
desolder and put nailpolish on it:
things I am working on: low fuel is wrong signal... I forgot to hook up cc. it isn't mounted and i need to move the dial to read the right speed.
Old Dec 5, 2013 | 07:00 PM
kaboomfox's Avatar
Default Re: 03 ex cluster swap into 96 ex (started)
Wiring diagram mostly correct (will update)
Old Dec 8, 2013 | 03:38 PM
xero_xero's Avatar
Yep. Colpetely working.
Ect? Buddy just put my em2 cluster in my old eg...
Old Dec 8, 2013 | 03:41 PM
Marvin1985's Avatar
iPad in dash em2 cluster in EJ. Very nice. Different
Old Dec 8, 2013 | 08:27 PM
tony_2018's Avatar
Fish Twig
So the issue with this install was only the temp gauge, were you able to confirm that? Can you show the location of where you soldered it to?
Old Dec 9, 2013 | 07:32 AM
kaboomfox's Avatar
These lights: http://img43.imageshack.us/img43/658...oncluster1.gif
are all controlled by a cpu so you have to find then on the circuit board desolder them, and solder a wire directly to the led. This bypasses the original signal.
You also have to do this for the trunk(controlled by multiplier) and headlights.
The image above show the temp. There are 3 pins on the motor and one says "unit". You desolder this one and make sure it doesn't touch anything else. Use a glue gun to isolate it and solder a new wire to it.
Hope that helps. I'll upload better pics soon.
Old Dec 9, 2013 | 02:57 PM
tony_2018's Avatar
Fish Twig
Its not a really good image thats why I asked. I know you're probably done with the swap. Hopefully someone else thats doing the same thing will shine some light to this with images of the location. Gj though! I've been wanting to do this.
Old Mar 25, 2014 | 09:22 AM
Contender_h22a's Avatar
Any write-up on this? Been waiting for years! I did the wired diagram already. Temp is now going up. I would want to know more about the "Desolder and nail polish" or "Desolder and solder them to LED". I want to know more. A full write-up would be appreciated.
Old Aug 26, 2014 | 06:13 AM
Spyda51s's Avatar
Icon3 Re: 03 ex cluster swap into 96 ex (started)
Same here been waiting we just need better pics hope someone is out there who is part of this site to help us out. Thanks in advance
Old Aug 30, 2014 | 03:47 PM
Spyda51s's Avatar
I been soldering wire to led . TAs far as the temp unit wire I de soldered it it and removed it from the board. Do I solder a new wire to the "unit" leg or the board.
Old Jun 7, 2018 | 10:02 AM
civicboy420's Avatar
Bring back from the dead! Trying to find the full diagram that shows everything, Please help!!
How did you get the temp gauge seperated from the cluster? Remove the needle?? Thanks in advance
Old Jun 7, 2018 | 10:57 AM
tony_2018's Avatar
Fish Twig
I recall the OP cut the signal from the rest of the cluster and solder the temp gauge wire directly to the cluster. Keep digging and you'll see an image floating around here somewhere.
Old Dec 10, 2025 | 02:43 PM
Anique's Avatar
I am currently on this Swap. Doing it to my 96 Civic Coupe. It has been a headache doing everything from scratch. I am Taking all the detailed pictures as I go. If all goes smooth, i ll be posting all the details, start to finish. As NO THREADS OR VIDEOS anywhere are complete.
I ll be making a youtube guide for all of us, so that this topic gets soeted once and for all 😅
Fingers crossed.
Uploading a picture of my progress until now.
See you soon
Cheers
Old Dec 11, 2025 | 12:36 PM
Anique's Avatar
Hi folks.
Here is the link to my youtuve video
I have tried to explain everything PCB wise in this one
will be uploading more regarding EK cluster loom and pinouts for this cluster, what goes where.
Hope this helps.
Enjoy 💯
Old Dec 12, 2025 | 04:32 PM
Anique's Avatar
Old Dec 12, 2025 | 04:35 PM
Anique's Avatar
I have attached all the Pinouts for both 96 & 03 civic cluster plugs.
I added 100 ohm- 1 watt resistor in series to the Unit wire of Temp gauge.
Have to know exact resistance for the Fuel gauge.
Hope this helps.
Thanks all
ek_sick
Dec 26, 2008 12:42 PM
95 GSR B20VTEC
Oct 29, 2008 11:43 PM
HapaHaole
Jul 11, 2001 12:23 PM
